Suspension settings question - Picture request BBS RC or Arc-8's
    18x10 et25 rear
    18x8.5 et38 front
    no spacers
    stock alignment
    dinan springs
    Awesome 👏🏼
    -Singh
    2004 e46 ///3 | Laguna Seca Blue | Black Leather | 6MT | Coupe | OEM+​
    BBS RC | Supersprint | Ground Control | Besian | Euro
      Unless the small wear indicator arrow on the outer tread block is being scrubbed away, probably best to stick to stock alignment.
        Cool, thank. Are the numbers I found on the build journals website accurate for stock alignment?
        -Singh
          It is somewhat correct. Here is the factory alignment -
Name:	Screen Shot 2021-07-30 at 7.28.20 PM.png
            My brief is different to yours.
            Daily driver.
            slight lowering.
            Square set up for front bite.
            square set up for rotation road hazards, etc.
            Even tire wear.
            18x9.5 et 22. 12mm rear spacer.
            265 35 18
            1.4 neg 0 toe front. So poke looks a titch silly.
            1.7 neg slight toe in. In the rear for the wet.
              Yet to be aligned since Ohlins slapped on yesterday, but here is my setup.
              ohlins rt
              apex arc 8 18x9/10, no spacers
              245/40, 275/35
                18x10 et25 rear
                18x8.5 et38 front
                no spacers
                stock alignment
                dinan springs
                More please. This looks so good.
