I’ve been looking to do the full subframe reinforcement for a little while as I track the car from time to time so I finally bit the bullet and got it done by Laszlo at Protodrive Autosport in central NJ. I know there are many solutions out there and even more discussion topics on which one is the best one. After doing good amount of reading on forums and different websites, I decided to go with CMP and do both the topside beam / front cups and bottom plates. It might be an overkill but I don’t want to have to do this again. Another consideration was if I get more into tracking and want to get a welded cage, this could be a good welded solution to connect to down the line.
Also, did bunch of “while you’re in there” items as well (CMP solid subframe bushings, OEM diff bushings, diff bolts, tack welding RACP pockets, front sway bar mount reinforcement, refinished subframe (POR-15), etc.
Interesting part, no noticeable cracks…for a 2001 manual with 90k miles (in case anyone was interested as I feel it’s a lottery with these cars). Here are some pics…I’ve been looking for them when I was thinking about doing this so wanted to share with the community.
Lastly, Laszlo was great so feel free to contact if you’re thinking about getting this done in NYC metro area.
[email protected]
iG: protodrive_autosport
Final look
[email protected]
Final look
