Closeup of my Vanos oil pump (after a paltry 54k miles). Note the clear indentation (which is also on the other side of the hole) caused by the tab on the spline impacting on the hole - adding at least another .5mm of gap that increases further the accel/decel impact of the tab on the hole. No wonder the tab eventually fails from metal fatigue
Is this why Vanos oil pump fails?
Originally posted by poss View PostCloseup of my Vanos oil pump (after a paltry 54k miles).
Were you the driver of those 54K miles, and what is the typical engine rpm range? I think more rpm changing in a quick pattern , rhythm, would cause more hammering on those disk holes. I would think the disk spinning speed is more stable than the cam hub as the regulated output oil pressure is stable.
Originally posted by LatinSkllz View PostWho’s re-drilling the disc for you?
Vanos all reassembled and working like a charm.
Mine had hardly any wear after about 100k kms. Nothing like that photo.
Yes smaller holes is the theoretical fix and I've not read of anyone having a failure with a modified pump disc (genuine redrilled or a Beisan one). That doesn't prove the fix but does support it.
That said, once moving I would not expect the free play to be much issue. The disc will "drag" as it's pumping and the tabs should always be pushing it around. I don't see how the disc would ever get ahead of the tabs and then end up being hit again. However the tabs do break and some discs like yours end up with significant wear. Perhaps if they start to wear a bit, it accelerates as the free play gets bigger.
Originally posted by Shonky View PostMine had hardly any wear after about 100k kms. Nothing like that photo.
...once moving I would not expect the free play to be much issue. The disc will "drag" as it's pumping and the tabs should always be pushing it around. I don't see how the disc would ever get ahead of the tabs and then end up being hit again...
Although they're quite different parts of the car, it's the same fundamental metal fatigue equation that cause both the oil pump tabs and the RACP to fail (at least in terms of the subframe rubber bushings deteriorating and causing them to hammer the RACP) - Number of stress impact cycles and the force of the impacts. If you drive the car hard regularly you are more likely to experience stress fractures in both the RACP and the Vanos oil pump tabs.
There's more to it than just the dimensions of the disk's holes. My 124k 02/2002 s54 had zero, I mean zero, markings whatsoever. Literally looked brand new.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Originally posted by Tbonem3 View PostThere's more to it than just the dimensions of the disk's holes. My 124k 02/2002 s54 had zero, I mean zero, markings whatsoever. Literally looked brand new.
That said, after a decade of people installing the smaller hole Beisan disk, with not a single known failure, I feel like the solution is reasonably proven out at this point.
