Michelin Pilots Worn Out with 6K Miles REVISED TITLE Actually 12K Miles in 3 Years
    Guess I've also got a lot to learn about posting here! Here's the correct information. Michelin Pilot Sport A/S 3 installed 2-8-17 at 86986 miles, and aligned at that time. Current alignment was done 1-18-2019 at 93086 miles. As of today, the mileage is 98252, so the tires have about 12K in 3 years. My concern is how much the tires have worn is 3 years and ~12K miles, if the alignment is basically solid.
    Sorry about the errors and confusion. I'll never get how to post my photo's, but here's the numbers from the current alignment done January 2019: Looking only at the rears: LR camber -1.6 degrees, toe +.18 degrees. RR camber -2.0 degrees, toe +.15 degrees. Total toe +.33 degrees. As mentioned elsewhere, I drive this car like a sissy, but acknowledge driving habits can factor into this question. Bottom line, if the current specs look OK to the crowd, and I need new tires soon, I'm asking for recommendations for other than the Pilots I now have.
    Thanks,
    Steve
      Thanks,
      Steve
      I don't think the problem is with the tires, if you drive like a sissy. They're a 30-40,000 mile tire, driven lightly.
        Have you noticed any quirks in the handling? Bad Rtabs could/can make the rear of the car feel like it sorta wanders, especially at highway speeds.
          The RTABS are poly and were installed November 2011 at 70000 miles. I replaced the FLCA about 3 months ago, and had no noticeable driving quirks at that time. FLCA had a worn ball joint.
            Your rear toe alignment spec is ok, you could run 0 toe in front on square setup and rotate. That said, 6k miles on Michelin A/S tires - something is definitely off, they should last much longer, they are 500 wear all season rubber with 45k mile warranty. Check all bushings and ball joints.
            Youtube DIYs and more
              Separate note - looking at your numbers you posted - toe variation of a few hundreds is ok, camber variation of several tenths - makes me question why, normally alignment shops are able to get the camber spot on, maybe 1 tenth diff right to left - yours is almost 0.5 degree. Was your car ever hit/in accident/bent frame, bent salad tongs (lower control arms), some busted/cracked bushings? I'm assuming on those tires you don't drive it too hard to actually feel if anything is loose?
                worn RTABs for sure is causing all this.
                  To my knowledge, the car was never wrecked, aside from a suv denting the front bumper a few years ago - replaced bumper cover only. I did replace the front control arms last year due to a torn ball joint boot, but the poly RTABs were installed in 2011 at 70K miles. Just remembered that I replaced the steering coupler last year; if that wasn't dead ahead straight, maybe it causes the car to track off center? I plan to lift the car this weekend and will get photos of the RTABs and tires posted. Thanks for all the input. I need to get this sorted before buying new tires.
                    What brand of front control arms did you install?
                    Aftermarket poly RTABs could be shot already.
                    What you're experiencing is not an issue with the tires.
                      A "street car" alignment will not always have an even camber/caster setup. In a perfect world you would and roads would be flat. But because of road crown with an even alignment the car will tend to drive to the right. A common trick is to add just a little bit of pull to the left which will help the car drive straight on crowned roads, this can be achieved by variances in the camber/caster side to side.
                      *edit - note, this would be done to the front, just a fyi.
                      Maybe I missed it, but is the car lowered or had adjustable LCAs in the rear? Thats a decent amount of rear camber for a stock setup.
                      Email to [email protected]
                        The front control arms are BMW OE, don't know about the RTABs.
                        Maybe I need to clarify - the correct miles on those tires is a total of 11266 over a period of 38 months. The RTABs are 9 years old with ~ 28K on them. Time to replace them?
                          He only posted rear numbers.
                            Probably RTABS, yes, but can you show a pic or define better what "worn" means - is it across the width of the thread that they are 3/32 or just inner edges? Also, assuming front tires were installed at same time - are those not wearing as fast, I didnt see a mention? Asking because your post only refers to the rears, but how are fronts doing in comparison. Given your driving style described, you probably dont experience power slides or wheel spin in rear to cause additional wear.
                              I experienced the same exact thing. My RTABS were shot on my Michelin Pilot Sport 4S and it killed my rear tires. It's most likely your case. Also, your alignment can change in 12k miles if you drive on harsh roads / hit a pot hole.
                              2002 Jet Black · 6MT · Cinnamon · CSL Tribute
                              Engine · Karbonius CSL Airbox · CSL DME · Kassel MAP · Paul Claude Tuned
                              Exhaust · SS Stepped V1 · SS 2.5 Res Sec 2 · SS Sport Sec 3
                              Suspension · JIC Cross/ZMS RS coilovers · GC Weight Jackers · SDW RTAB · Corner balanced
                              Wheels/Brakes · BBS E88 18" x 9.5" / 10.5" · Michelin Pilot Sport 4S · 996 Brembo BBK
                              Exterior · Mile End CSL bumper · OE CSL trunk · Mile End CSL diffuser · OE LED taillights
                              Interior · Avin Avant 4 · Llumar Air 80 Tint
                                OK, guys, hopefully, here are photos of the rear tires, RTABS, and the shop's complete spec sheet. I measured both rear tires with an accurate scale, and the innermost groove depth is 3/32, outermost is 4/32. The RTABs look pretty good to my untrained eye, and I don't know the brand name. They were installed by a very reputable shop in Seattle, so I'm guessing they are quality units. If I can add anything further other than whining, let me know!
                                Steve
Name:	Alignment specs.jpg
ID:	13737 Click image for larger version
Name:	Right RTAB 98500 miles.jpg
ID:	13738 Click image for larger version
Name:	Left RTAB 98501 miles.jpg
ID:	13739 Click image for larger version
Name:	Right Rear Tire 12000 miles.jpg
ID:	13740 Click image for larger version
Name:	Left Rear Tire12000 miles.jpg
