I feel dumb- which adapter do I need for my 03 M5. Can't find the blue one anywhere but can't find the black one either (unless thats it, connected below)
You have the ULF over the Navi, so the 54-pin adapter
I was going to give you the ole "lol idk" BUT I went and looked in WDS and found this:
As you can see the, the reverse gear switch is tied directly to the reverse lights on the E46, while in the E39 that signal is sent to the Instrument Cluster.
The IKE is then able to communicate the status of reverse gear since it has this input, while the circuit on the E46 is purely analog.
Thanks for that! Mystery solved. I now know one additional useless fun fact about our cars 😂
Thanks for the new firmware release !
It seems that I still have the issue where "Music" app is not updating metadata. With the same phone, if I use Spotify instead, it is updating by itself.
Firmware 1.3.0, HW 1, iPhone 12 Pro, iOS 16.0.3
Thanks for investigating !
Thanks Ted. Iirc I was seeing no disc and no jacket when scrolling through modes. There is an aux cable for iPod previously installed idk if that matters
Can you confirm that you are seeing "NO MAGAZINE"? That means you have an iPod module and you'll need to pull the radio out and remove the module, then reinstall the factory ten-pin audio connector in the radio's quadlock. Email for more details.
The BlueBus isn't discoverable by default. If you don't have Navigation, are you seeing a mode called "CD 7-01" or "CDC 7 TR01-0001"? If you are, just turn the ignition off, close the car, then come back in five minutes and it should sort itself out. The "6" button is used to make the unit discoverable.
A Bluetooth module for vehicles equipped with I-Bus - tedsalmon/BlueBus
Thanks!
-Ted
Hi Ted, thanks for the v1.3.0 firmware. Can you tell me where you look for the oil temperature? I want to make a module that grabs it from the CAN bus and translates it to Ibus. Just like the eLight module, but with real data from the ECU instead of the guesstimation from TOENS.
At the weekend I had a quick chat with Kevin, who is trying to build Bluebus from the open source documentation, quite nice guy
This is a difficult proposition. I pull the oil temperature from the light module using diagnostics commands. Perhaps we could use an unused device address and op code to shoe horn support for what you want? I wouldn't mind that.
Just installed my bluebus. I see the led on the right side lit. No option for Bluetooth on my deck and bluebus not showing up in my phone’s Bluetooth . Pls help
I looked through the thread and all through YouTube installs and I can't seem to find my answer. I have an E46 with the CD Changer and the Sat Nav in the rear electronic cluster. I was able to locate the extra sleeve with the TCU and a 3-prong power cable, but the extra sleeve did not come with either the analog or digital audio cords to connect to the BlueBus. Am I supposed to disconnect another piece of equipment in order to get the 6-pin to plug in to the BlueBus? I do not have a DSP Button but I do have the HK System, and the Speaker button on the same console as my climate control buttons. Any help would be greatly appreciated
Easy! You have to rob the CD Changer of its connector, then bin the changer
Did you wire I-Bus to the amplifier? Unlike the H/K unit, the Professional Amp is configured over the I-Bus by the radio.
-Ted
Yes, of course, otherwise I wouldnt see the DSP option and wouldnt be able to control the volume at all. Radio module goes into fixed output volume when a DSP is seen on Ibus.
