  • t3ddftw
    Originally posted by sda2 View Post
    There is no benefit in using the other wiring harness, I just bought it to make sure the wiring I have is correct You can simply change the 3 pin connector on the vehicle side to 2 pin connector to match the midtone speaker and tweeter. E46 hifi system btw. does not have the right impendance (8Ohm) vs. HK/Top-Hifi (4Ohm).
    Sounds great, but I was not able to use the equalizer function with the Nav MK4 and a late 2005 BM54 module. Maybe that is because I had the Intravee connected with Alpine DSP directly before.
    Did you wire I-Bus to the amplifier? Unlike the H/K unit, the Professional Amp is configured over the I-Bus by the radio.
    Originally posted by VisorM3 View Post
    I have a new one for sale with the adaptor if anyone wants a small discount, sold my M3 before being able to install the Bluebus
    I wouldn't take a dime less than you paid for it, personally.
    -Ted
  • VisorM3
  • sda2
  • t3ddftw
    Originally posted by nahvkolaj View Post
    That did the trick! Thanks!
    Glad to hear it!
    Originally posted by Obergoose View Post
    Appreciate the technical details! Attached are pics of the amplifier I pulled from an E83 (modified w/the SMB jack) and the 10Ω woofers from a top-hifi E85. I'd like to emulate your retrofit approach so will hit the scrapyard again tomorrow to pull the remaining speakers from the E85.
    Can I ask what benefit there is to swapping the whole speaker harness out? My intent was to use the existing harness and just replace the terminals at each speaker and the amplifier. Admittedly, I'm a bit of an amateur when if comes to car audio.
    I'm interested as well, lol.
    -Ted
  • Obergoose
    The Logic7 amp from 7-series E6x (MOST System) is not compatible with our Kline architecture. Front high/mid and read high speakers are connected to the ASK unit ("radio module" if you want to call it like that) and the subs and center and rear mid are connected to the external amplifier.
    There are two options for DSPs with our E46s. The E38/E39 and E8x Top-Hifi amplifier units. E38/39 doesnt match impedance of our speakers. E83 doesnt match the pinout, E85/86 matches perfectly, but you will loose factory subwoofers. Touring doesnt have these, so its a perfect fit.
    The E8x DSP amplifier has an internal powersupply that creates 30V supply voltage for the two TDA8926TH chips giving us 2 channels with 100W output power. On E83 these outputs are used for the subwoofers (Zentralbass) under the front seats, and E85 uses them for the carver design subs behind the seats.
    Wiring is what makes the difference, but I will go into detail on that in the other thread. I have a complete set of E85 speakers including wiring on the way, so I can change the whole system to those speakers.
  • nahvkolaj
    Sounds like your BM53 crashed. Pull the fuses for the radio and Navi and try again
    -Ted
  • Andy2424
    Hello Ted, I just wanted to say thank you, I got my first one in sept 99 :-) It's been working perfectly ever since... THANK YOU
    Order 50 :-)
  • t3ddftw
    Ted, I was about to write you an email saying the Bluebus wasn’t working this morning, but I waited to see if the problem persisted on my drive home from work.
    The left side buttons to my head unit (E46 full screen Nav) do not work and none of the audio modes work. The OBC and Settings menu work with the right hand controls. This is all the screen showed this morning, but I can’t even get it to display this now.
    Unplugging the Bluebus didn’t make any change. Anyone ever have this issue and solve it?
    -Ted
  • nahvkolaj
  • sleeks
    I'm waiting for confirmation, but likely two weeks from now. The July batch pushed back the September batch, unfortunately.
    Thansk!
    -Ted
    Sounds good. Thank you.
  • t3ddftw
    Originally posted by sleeks View Post
    Sept orders going out soon? Is there an estimate on when those will ship? Order #2580
    Thansk!
    -Ted
  • sleeks
  • t3ddftw
    Emailed your support. Have had an order since last October and still nothing…
    Just shot you a response.
  • Chas3n
  • sda2
    Regarding power, I just blew the two factory "bass" speakers in the trunk of my touring. I will put the two 6.5" carver subs in a 2x10L enclusure or maybe they will work in the factory touring cages.
