Very low mileage but long time on oil. Do I really need to change?
OP the same thing happened to me. Between 2017-2020 I only added 1,200 miles on my car. In between that I did an oil change in 2018 and another one in 2020. I just had my oil changed this past month when I had my rod bearings replaced. It’s been about 400 miles since my last oil change in 2020.
On average Ive added about 500-1000 miles per year for my past 16 years of ownership. I have the oil changed every April at the beginning of car season along with my NY state inspection.
Overkill? I’m sure it is. But I’d rather be safe than sorry.
Off topic, are you keeping the car on a battery tender while the car isn’t in use ?Last edited by DropTopKingM3; 09-14-2021, 10:53 PM.
interesting. in that time have you seen any non-use type of wear? leaks, bad seals etc? I start and drive it lightly about 3-4 months on average. all the fluids are new except the p/s fluid, and ive gone out of my way to use OE on everthing and pentosin for brake fluid.Originally posted by DropTopKingM3 View PostOP the same thing happened to me. Between 2017-2020 I only added 1,200 miles on my car. In between that I did an oil change in 2018 and another one in 2020. I just had my oil changed this past month when I had my rod bearings replaced. It’s been about 400 miles since my last oil change in 2020.
so i have one of those green battery tenders. i was leaving it on the tender for months on end and it killed the battery and took the airbag module with it (battery was low and undervolted on startup and somehow locked the airbag module out) so now i just pop it on the tender for a week or two, and pop it off and let it sit for a while, seems to keep the battery in good shape.
i have one but the hose isnt long enough to put down the oil dipstick tube. i need to pick one up, or maybe get the blackstone sucker.
Fun fact: last oil change in 2018. i completed the oil change, before a track day... went to check it and it was WAY overfilled. being pressed for time, i had the dumb idea while the motor was warm/hot to undo the drain plug quick and let some oil out and put it back in. it didnt go to plan and i couldnt get the drain plug back in time, and the hot oil almost burned my hand.. i had to let the entire thing drain out with brand new oil... then I had to spend the evening driving around auto part stores to find 10w60.
Next day track day, car blows powerflex FCABs i had just put in.... since then the car's been fixed mostly sitting. lol.
I use the old school oem BMW battery tender that plugs into the cigarette lighter. My last Bosch battery lasted nearly 9 years as a result. The only reason why it crapped out is bc someone unplugged the trickle charger and the battery died down and went kaput after that.Originally posted by sev View Post
As far as seals and leaks there haven’t been any out of the ordinary. The typical CPV o ring and valve cover gasket. I do have flat spots on my continental tires. I’ll be replacing them since I’ve had them since 2014.
