Hey guys! It's great to see that a forum is back up again!
Anyways...
Late 03 build/2004 model, with factory Xenon. I've gone through 3 ballast within a year. I've changed the ignitor & wires, still having the issues. The issues (flickering & turning off on bumps) happened more frequent with each replacement ballast. The last one I installed died almost instantly after turning on. Albeit, on this last ballast I added a ground wire... which has helped a friend remedy the same issue on his personal e46.
*notes
- I changed my alternator halfway in this same time frame.
- I've visually checked and cleaned grounding point by turn signal
- I've visually checked for any pinches/frayed wires
BTW I purchase the AL OEM Ballast 63127176068 from lighting way for the last 3. They seem to be the same exact part, with just the AL part number and not the BMW. Luckily, they have been working with me on warranty since they happened within the year.
Is it possible the bulbs could be causing it? Maybe shitty/fake ballast? I want to get some ideas as I don't want to just keep throwing ballast at it, trying to test.
-Raj
Anyways...
*notes
-Raj
