712 steering rack question
    Hi guys
    Does anyone know 100% if you need to code the dsc module ???after install 712 rack on left highway curves dsc cut throttle and only at left turns ...i try on right curve same km nothing....anybody can help?
    Sent from my LM-G900 using Tapatalk
    Fwiw
    I have M-Track mode coded I remember when doing so I set it up for my green tag rack. If I go to a ZHP rack what value or "wert" should I be using? Thanks. It's currently set to "wert_05" under "LENKWINKELKENNLINIE_2" in the MK60 module. Edit: It's "wert_04", found it searching around,
      Thanks alot
        You should code it for ZCP/CSL rack settings.
        Interesting yours only triggers intrusively on left curves. Makes me wonder if you truly centered the rack’s center notch located at top of dust cover.
          I check everything...i even swap axles to be sure is not the ring....just left the coding because when i swap it 3 people told me you don't need to code it
            Well..now what do you think about those 3 people compared to the ones who said you should??
            It’s just follows logic that the steering angle sensor will be reading improperly for what is going on and triggering.
