Fitment for style 67 on a e46 m3
    Hi, I wanted to know I can run the rear pair (18×9)of the style 67 wheels in the front of my e46 m3 with a stock suspension set up.
    Should fit no problem IIRC
      I think most people will run spacers in the back to even out the stance.
        You can, but they will poke out quite a bit from the fenders without sufficient camber. The best-case scenario is if you swap the top hats on your struts for the maximum allowable camber you can achieve with stock parts, and even then there will still be a decent amount of poke.
          They will fit. For reference, here are some old photos of my car when it was on Square Style 67's. 265/35/18 all around.
          I used MADRUSSIAN's free camber mod and it was enough camber. Car is lowered on springs not coilovers in these photos.
            I appreciate it guys I'll be sure to send pictures of the cars with the wheels on
              Ideally, you need camber plates. But they do "fit".
                Originally posted by RoyalFlushness View Post
                This is a perfect illustration of why you'll want spacers in the rear, look how sunken in they are compared to the fronts. Applies to any square wheel setup on these cars.
                  For contrast, here is my car with square 67s and a 12.5mm spacer in the rear only. I am running camber plates + coilovers FWIW.
                    Here's mine on stock suspension, 12.5mm spacers in the rear, and stock size 255/40/18s.
                    Sent from my SM-G988U using Tapatalk
                      How much camber is necessary to tuck them in?
                        Nice fitment.
                          Here is my set up. 265/35/18, 3 deg camber F, 2.4 deg camber R, 10mm R spacer, slightly rolled rear fender.
                          2003.5 SG/Grey
                            Looks great. That's a lot of camber. Any issues with edge wear in the front?
                              Not really. The car does 3000 street miles and 1-2 track days a year though.
                              2003.5 SG/Grey
