Originally posted by Obioban
Today is the day!
I would go back to basics first, start small and move on to large as well as the comp and leak down.
If you haven't already or it's time I would r&r:
coils/plugs
cps/tps/o2s
check fp/clean injectors/ replace fuel filter
vanos test2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
Originally posted by jet_dogg View PostI would go back to basics first, start small and move on to large as well as the comp and leak down.
coils/plugs
cps/tps/o2s
vanos test
Originally posted by LSBNick View Post
Everything on this list has been addressed except the TPS. I’ll have to go through my records and receipts to verify when and what brand of new parts were installed. Most, if not all, were purchased through FCP euro2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
Quick update for those who are semi-following. Car threw bank1 and bank 2 lean codes today on the way to our local CCA meet. Given the fact that this is after the tune, I’m leaning towards a vacuum leak (hopefully) being the main source of my problems.
I still plan on doing a compression test, and depending on results, a full leak down test, but wanted to ask to forum if anyone has experienced something similar to my situation, and what the most common vacuum leak on S54s are.
Thanks for any input/help in advance!
There's very few potential sources of vacuum leaks on this engine because of the ITBs and they're all around the throttle bodies. If you had the stock intake and MAF there could also be unmetered air leaks to worry about, as that would alter the mixture. However, since you've got a CSL airbox, all you have to worry about is vacuum leaks.
These are all the ones I can think of:- Thottle body to head gaskets
- Idle ports o rings
- ICV to throttle body piping
- Brake booster vacuum line
- Fuel pressure regulator vacuum line
- The idle air rail itself (pinhole somewhere or something)
- Emissions solenoid thing, but you'll only have that if your car is an 05 or 06
In your old thread you said the same thing about getting the compression checked, then you posted,
Originally posted by LSBNick View PostFigured I’d give a quick update here.
Car has great compression, and have since replaced my fuel filter, converted my EKP to a traditional fuel pump relay, and had my injectors cleaned/rebuilt as needed.
Retuned by HTE, car is now putting down 318 whp and 231 wtq.
Definitely an improvement, and glad Hassan was able to make his magic happen.
Currently trying to find a way into a SS V1 set up, and will retune the car again with that new setup.
As for now, car is running like a dream, completely linear power band, and is a blast to drive. Thanks for all those who gave their input and experiences!2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
Originally posted by jet_dogg View PostIn your old thread you said the same thing about getting the compression checked, then you posted,
Now you're again talking about getting the compression checked? I think it's pointless trying to diag your issue when we don't know exactly what maintenance with what parts has been done to the car.
I work what seems to be 24/7 but will finally have some time on Tuesday to go through my records and see what exactly was done with what parts and when. Once I have everything compiled I’ll post here with as much detailed information as I can gather.
stash had mentioned to double check o2 locations as well, though the two shortest are pre-cat and the two longest are post-cat2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
