You literally posted a picture of the location for convertible which is behind the RR "door" panel, the coupe is located in the trunk. Are you even reading my posts?
The DME has two fuel pump outputs, one is PWM and goes to the EKPS on US cars (X60002 pin #11) the other is to ground the fuel pump relay coil on EU cars and all non-m us E46 cars (X60004 pin #10). ***Because of this you don't have to make any changes to the fuel pump system when doing a S54 swap into a Non-M E46 chassis.
Originally posted by George Hill
Originally posted by sapote
