Removing Poly Subframe Bushings
    I had polyurethane bushings installed when I had my subframe reinforced but I'm getting ready to drop the rear end and install solid CMP bushings.
    What kind of surprises am I going to run into removing these poly bushings (only been in for around 6k miles)? Any best practices, tools, or recommendations for the process?
    Edit: I'm fine dropping the rear end, just haven't dealt with poly and wondering if these will be harder or easier to remove than OE.
    They should be easier to remove than OE bushings. When I did my reinforcing (fall of 2018), I removed mine to inspect them. If I remember right, you should just be able to remove the center sleeve. Then with a blunt punch and a mallet/hammer tap one half out by tapping it out on the inner half edge. Should come right out.
      They are 2 piece with a center sleeve. 2 piece meaning half of it enters the subframe from top and the other half from the bottom and they meet in the middle. VS OE rubber, which is 1 piece and the entire thing has to be pressed in from one end or the other. When I did AKG, I could press them in hand tight, didn't need a bushing tool/press.
      Youtube DIYs and more
        Thanks guys. I got all the fiddly bits out of the way meaning the exhaust, heat shielding, driveshaft disconnected at differential, plastic bits, parking brake, etc. Wrap up dropping the rear end tomorrow and then wait on parts to arrive.
        You all disconnect the brake lines from the calipers or simply remove the calipers without disconnecting and hang?
          I disconnected because I was rebuilding them, but you prob wont have much to hang them on, if entire subframe and control arms are coming down.
            ^Good point gizmo... LoL. Not a lot left. If I can rig something I'll let them hang otherwise I'll disconnect.
              I can't remember where I hanged mine from, but I didn't disconnect them when I did my plates.
                You could remove the rear shocks and hang them from the holes.
