So my friend's 06 M3 had its cam bolts replaced with the updated torx head BMW bolts which proceeded to snap just like the previous bolts in 12k miles. Is there a possibility that the previously snapped bolts damaged the threads and caused this to occur once again? Has anyone experienced something like this or recommends a different type of bolt?
Cam Bolts Broken After Replacement
Journal: https://nam3forum.com/forums/forum/m...grey-speed-runTags: None
100% this. The issue with those bolts is them getting loose over time. Original bolts, updated bolts, aftermarket bolts, doesn't matter-- the key is installing them correctly (torque spec and loctite).Originally posted by sapote View PostDid he use Loctite on the bolts threads
Red Loctite was used, and it was torqued properly according to my knowledge. Can even slight over-torque cause this?Originally posted by sapote View PostIt’s not about stronger bolts, but it needs to prevent them from backing out by using Loctite2003.5 E46 M3 Silver Grey/Cinnamon
We did not use a hammer to remove the previously snapped bolts, just used a pick and spun them out. We wouldn't have even caught this if we weren't swapping out his cams.Originally posted by sapote View PostI'm interested of seeing the cam sleeve 6 holes, and how bad they had been distorted after hammering on the bolts to cut a notch.2003.5 E46 M3 Silver Grey/Cinnamon
Not as a tool, but the hammering effect when there was plays between the sleeve and the loose bolts.Originally posted by Sid_E46 View Post
Oh ok, I'm not quite sure. The car is getting new cams so let's hope it doesn't happen again. We will probably use a decent bit more red loctite this time.Originally posted by sapote View Post
What torque is recommended for these bolts? And does going over that number a little pose a risk?2003.5 E46 M3 Silver Grey/Cinnamon
Loctite 243 is oil tolerant; the standard blue loctite 242 and red are not.Originally posted by Sid_E46 View Post
We used the red gel loctite, that isn't oil resistant?Originally posted by Slideways View Post
We are going to use the lang racing bolts and 243 loctite this time. Is 9 ftlbs the recommended torque?2003.5 E46 M3 Silver Grey/Cinnamon
