Originally posted by Sid_E46
Cam Bolts Broken After Replacement
I believe I may have done 12 ftlbs but would that be enough to cause damage.Originally posted by sapote View Post
9 ft-lbs. clean the oil off the threaded holes and the surface at the end of the cams where the sleeves mate on. Metal to metal and no oil here.2003.5 E46 M3 Silver Grey/Cinnamon
Well, an M6 takes 12NM which is 9 ft lb, you gave them more than 30% so not ideal. I believe these are 8.8 class, if they are higher grade then you were fine, but I am almost sure the OE bolts are 8.8 classOriginally posted by Sid_E46 View Post
for sure some one will correct me if I am wrong
Yep, oe is 8.8 grade.Originally posted by maupineda View Post
for sure some one will correct me if I am wrong2003.5 E46 M3 Silver Grey/Cinnamon
For the OE bolts, yes. Especially since they're already kinda lubricated with oil +/- loctite when you're installing them.Originally posted by Sid_E46 View Post
Technically the OE bolts are upto the task if an appropriate thread locker is used. But it's very easy to overtighten. Stronger bolts gives you more wiggle room in that regard.
This is making me paranoid to check my own car now.Originally posted by terra View Post
This wasn't as much of an issue in the 01-04 cars though correct?Last edited by Sid_E46; 11-11-2021, 07:26 PM.2003.5 E46 M3 Silver Grey/Cinnamon
I was going to post this.Originally posted by maupineda View Post
The smaller the bolts the more critical slight torque variances become.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
Remember the Langs are grade 12.9 vs OE 8.8, I went about 12ft lbs if I recall correctly and used red oil resistant loctite.
Total overkill, wish I would have used the BMW torx bolts w/ blue 243 loctite. I may not be able to get those out down the road easily using the red.2004 Silbergrau Metallic 6MT
Not without a blowtorchOriginally posted by Cubieman View PostRemember the Langs are grade 12.9 vs OE 8.8, I went about 12ft lbs if I recall correctly and used red oil resistant loctite.
Changing cams is going to be extra fun
It's interesting to see the notches on the bolts cut by the splined sleeve. Obviously the sleeve only hammering the bolts in one direction -- CW I think. But in order to hammer the bolts, the sleeve must be running behind (slower than) the cam sometime, and then accelerated faster and hammered the bolts. The exact hammering effect was happing on the vanos disk holes by the EX hub tabs with the disk original larger holes. The modified smaller holes reduced the hammering significantly.
Yea, I dread the day I have to loosen those bolts.Originally posted by Slideways View Post
My hopes are if they won't come out in situ I could fully remove the TC tensioner and hopefully have enough slack to slip the sprockets off the hubs and then pull the cams with sleeves still installed so the bolts can be drilled out more easily.2004 Silbergrau Metallic 6MT
Yea, I'll bet I spent 10mins+ on each hole using various chemicals/cleaning tools to make sure the female threads were clean. That takes a while to do it correctly, you can't simply roll a q-tip around for a sec and call it good.
I found Locitie 768 cleaning solution and MEK along with some very tightly wound conical cotton q-tip like things for cleaning guns helpful. Also a dental pick was nice to get out the big pieces of old locite I had on mine as someone had already been in there.
I have a spare set of those parts so I had mine hot tanked. That is overkill but you can pull those parts off and properly clean themOriginally posted by Cubieman View PostYea, I'll bet I spent 10mins+ on each hole using various chemicals/cleaning tools to make sure the female threads were clean. That takes a while to do it correctly, you can't simply roll a q-tip around for a sec and call it good.
https://www.amazon.com/Tapered-Regul...08CPU4JW&psc=1
