OEM replacement windshield parts guide
    As part of my restoration I will be replacing the front windshield on my convertible. I’m going to order it locally through Westchester Ray Catena BMW. Which other parts would need replacing?
    Would the moulding around the windshield need to be replaced as well ?
    Thanks.
    That should be all you need, just did mine and had a new OEM moulding installed.
    Current:
      Thanks.
      Curious how much the glass will run you from the dealer?
        It’s kinda ironic but I’ll be getting the windshield from a friend who works at the BMW dealer and my friend who works at a Mercedes dealer is going to install it at work lol
          You might as well change the cowl, if it was never been changed.
            https://www.ecstuning.com/b-genuine-...51718232894kt/
            I'm curious, if the water get down through the old torn up cowl, where do the water go?
              Thanks bro. I purchased one last summer from FCP. I paid a few $$$s more but the lifetime warranty can’t be beat.
                There is a metal edge before it hits the engine firewall, so it drips down on the sides of the bay:
                That is why those plastic pieces on the side of the cowl get so nasty with time, change them!
                  As part of my restoration I will be replacing the front windshield on my convertible. I’m going to order it locally through Westchester Ray Catena BMW, and while researching, I also looked into Polaris Ranger XP 1000 accessories. Which other parts would need replacing?
                  Thanks.
                  Yes, the moulding around the windshield should typically be replaced when installing a new windshield. Old moulding can be brittle, cracked, or deformed, which can prevent a proper seal and cause leaks. Besides the windshield and moulding, you should also replace the adhesive/sealant and any worn clips or fasteners to ensure a secure, leak-free installation. It’s also a good idea to inspect the cowl panel and weatherstripping and replace them if they’re damaged.
