After a little bit of testing and trial and error, I have been able to narrow down a consistent misfire on my car at 4+k rpm under load and only under load. Issues started off as an intermittent cylinder 3,4,5 misfire (not noticeable but the code was there). This then progressed to the car shuddering and becoming a paperweight.
The car has suffered some rough idling issues but after resetting the adaptations and clearing codes the car was able to idle smoothly and rev up to 6k rpm while in neutral without missing a beat. Everything seems normal at this point. I went to take the car for a test drive, maybe kinda sluggish but drove normal and operable. Hesitation at about 3500 rpm and then right at 4000 rpm immediate misfires. Very feelable and the car really just not wanting to live. Off the top of my head, I believe I got the apparent 3,4,5 misfire from before. Along with an occasional cylinder 1 misfire code and then just one time a bank 1 fuel system code. All of these codes were through INPA.
All I have done to the car was to replace the vanos solenoid sealing plate. I may have accidentally overtightened my solenoid coil pack and caused a slight crack on the mounting joint. Although I do not think this caused my issue I have a new solenoid coil in the mail now. I have the valve cover off and from what I can see the exhaust hub tabs are in good shape and no apparent issues from what I can see.
Is there anyone out there who may know more about what my issue could possibly be? I'm waiting on amazon and their shipping delays to be able to check my timing with the timing tool.
A little aside, does anyone know of any other programs I can use to see a little more than inpa shows? I was hoping to be able to see fuel trimmings etc to see if I can visibly see my issue/symptoms through the OBD port (wishful thinking)
