IND | E46 M3 Red Sport / M-Track Mode Button Set Install Guide
    Click image for larger version  Name:	51748833386_89f9893bec_b.jpg Views:	3 Size:	107.2 KB ID:	152798
    With the release of our new Red Sport and M-Track Mode Button Set for the E46 M3, we put together a brief install guide.
    Tools Required:
    • T10 Torx
    • T20 Torx
    • Precision Phillips Screwdriver
    • Flat-head Screwdriver
    • Pry Tool
    STEP 1: Disconnect battery and remove airbag by inserting flat-head screwdriver or small torx head into the receptacles on the rear of the steering wheel and pressing on the retention spring that secures each side. Disconnect airbag plug.
    STEP 2: Remove x2 T20 screws that secure the rear of the lower steering wheel trim and the front x2 T20 screws from the inner steering trim. Remove the trim by pulling from the top section first and detach the M-Track Mode button harness prior to completely pulling the steering trim away.
    Click image for larger version  Name:	51749447199_1c47cc42da_b.jpg Views:	3 Size:	66.2 KB ID:	152779
    Click image for larger version  Name:	51748802036_50a308c393_b.jpg Views:	3 Size:	115.7 KB ID:	152769
    Click image for larger version  Name:	51747972397_79849fedac_b.jpg Views:	3 Size:	122.0 KB ID:	152770
    STEP 3: Remove x4 precision phillips screws from the M-Track Mode controller panel and remove plastic spacer securing button; replace original button with new red version. Installation is the reverse of removal.
    Click image for larger version  Name:	51748806941_364e690193_b.jpg Views:	3 Size:	84.2 KB ID:	152776
    Click image for larger version  Name:	51749687175_4de36d7a9f_b.jpg Views:	3 Size:	89.6 KB ID:	152777
    Click image for larger version  Name:	51749482289_2a1e8eaa5d_b.jpg Views:	3 Size:	98.4 KB ID:	152771
    Click image for larger version  Name:	51749714700_80fb34cfe9_b.jpg Views:	3 Size:	57.7 KB ID:	152774
    Click image for larger version  Name:	51748834776_f8c45ae665_b.jpg Views:	3 Size:	97.7 KB ID:	152772
    Click image for larger version  Name:	51747981597_4ab40953e7_b.jpg Views:	3 Size:	58.2 KB ID:	152778
    STEP 4: Remove shift knob by forcefully pulling straight up; being careful not to hit yourself upon release. Pull up on the shift boot to unclip its frame.
    Click image for larger version  Name:	51749710630_bac12bf215_b.jpg Views:	3 Size:	80.7 KB ID:	152780
    STEP 5: Remove phillips screws securing center console trim and detach window switch harnesses.
    Click image for larger version  Name:	51749073823_98d4996ae3_b.jpg Views:	3 Size:	73.2 KB ID:	152781
    Click image for larger version  Name:	51748001637_a46af678cf_b.jpg Views:	3 Size:	90.8 KB ID:	152782
    STEP 6: Remove storage compartment by pulling straight out. For cars with lower climate control unit, place tape on console sides and begin by slightly prying to release climate module. Once able, remove by hand and detach harness.
    Click image for larger version  Name:	51748827166_d08315af22_b.jpg Views:	3 Size:	102.1 KB ID:	152783
    Click image for larger version  Name:	51749070313_bfd8b58512_b.jpg Views:	3 Size:	96.9 KB ID:	152784
    Click image for larger version  Name:	51749472764_88a0e86cfe_b.jpg Views:	3 Size:	103.9 KB ID:	152785
    STEP 7: Remove screws securing center button console and ashtray frame; detach controller harness to easily expose the rear; ashtray lighter can remain connected.
    Click image for larger version  Name:	51748823576_36ac59c4ec_b.jpg Views:	3 Size:	144.9 KB ID:	152786
    Click image for larger version  Name:	51749466744_88d679254f_b.jpg Views:	3 Size:	162.1 KB ID:	152787
    Click image for larger version  Name:	51748818511_97b8b1c080_b.jpg Views:	3 Size:	139.1 KB ID:	152788
    STEP 8: Remove x2 T10 rear screws securing button console and remove.
    Click image for larger version  Name:	51749696190_7c424ff7b1_b.jpg Views:	3 Size:	111.0 KB ID:	152789
    STEP 9: Using a pry tool, detach the tabs holding the button console together. Pull the original Sport button off and replace with new red version.
    Click image for larger version  Name:	51749462114_124fc53d36_b.jpg Views:	3 Size:	111.6 KB ID:	152791
    Click image for larger version  Name:	51749693815_78f487dfa1_b.jpg Views:	3 Size:	102.8 KB ID:	152792
    Click image for larger version  Name:	51749057158_f790f6ccf3_b.jpg Views:	3 Size:	94.4 KB ID:	152793
    Click image for larger version  Name:	51747984867_26518c0734_b.jpg Views:	3 Size:	103.8 KB ID:	152794
    Click image for larger version  Name:	51749056153_10c46ebdd9_b.jpg Views:	3 Size:	103.3 KB ID:	152795
    Click image for larger version  Name:	51749690425_266ff4dd2c_b.jpg Views:	3 Size:	113.7 KB ID:	152796
    STEP 10: Installation is the reverse of removal.
    Click image for larger version  Name:	51748831666_180737b820_b.jpg Views:	3 Size:	104.7 KB ID:	152797
    IND DISTRIBUTION | 847-963-4520 • INSTAGRAMFACEBOOKYOUTUBEFLICKR
    Bro what.
    2005 BMW ///M3
    Black6MT Daily
      Very nice to see for the E46 M3 platform, although I don't have the Comp/CSL wheel, so I think getting just the sport button would look out of place. I can vouch for the quality, I have IND Red Start/Stop button and M1/M2 buttons on my M4 CS. Great company and quality.
        That's a nice DIY but I don't get it lol
          IG clout chasers bouta eat dis shit up and post some bokeh shots thirsty for likes and followers.
            It's still good to see parts being manufactured for our cars after 20 years. This one being aesthetical is minor, but good to see non the less.
              Excellent DIY and quality product from IND
                The Sport button? At first I thought it was for the DSC button and so was like Yeah ok at least the red would make it easier to quickly see it to turn off traction in the heat of a moment since it sits in that (imo) cluttered row of similarly shaped and colors buttons… but why the Sport button? Lmao I dont think IND knows these cars well, Sport mode is just the throttle mapping… literally pointless to bother changing that button. DCS button would make more sense (again imo), but hey at least they didnt complete forget about the E46.
                2004 CB/Cinnamon 6MT Coupe
                Youtube
                  I believe some of the new M cars have the red buttons stock-- that's the origin of this idea (I assume).
                    Wait, we're back to these types of mods?
                      Looks like a quality product, may have to get a set.
                        slightly off topic but was at the dealer today to grab some washers for the crankcase vent oil return line and had the displeasure of overhearing the convo the gent in front of me was having with the parts guy. they were trying to find the correct part number for his "vermillion special edition grill." lets please keep the new bimmer stuff with the new bimmers.....
                          BourgeoisMotorenWerke
                            Ah darn, thought someone came up with a retrofit M-Track button add-on and wiring kit for steering wheel. Come up with something like that with a green or purple Mtrack cluster LED and I’m all over it.
                              Love it.
