my V2 kit came with the incorrect large pinion bearing, which was the ball bearing type used on the E9x M3/ E6x M5&M6. The Z4M uses the same bearing set as the E46 (either V1 or V2). So I had to buy this Koyo bearing separate, not a biggy.
What is now making me wonder I have the right parts are the seals, sound like the seals may be different too?
Edit: the V2 should be more stout for the reasons above, and they have 8 clutches, this is logical as the diff needs to handle the torque of the V10, which though not much, it is more than the S54's.
Edit2: For my rebuild I have decided not to open the diff, just change bearings and the crown and pinion for the 4.1 ratio. not worth the hassle in my eyes, plus my diff is fine. it clunks but it also locks up perfectly fine.
Edit3: I have checked real OEM and the seals are shared with the E9x M3 and E6x M5
So the issue is just the large pinion bearing, all other bearings are the same.
. Agree if v2 came with more clutches I'd be more inclined to go through the trouble of rebuilding a v2 lsd unit. But if it's the same as v1 and has so many more hops and procedures to take apart and put together and reset backlash, I think it's a no brainer to just use v1 lsd units.
