Timing chain tensioner seal replacement
    Not a good idea using the thread sealer, the oil input is before the threads, waste of time, I am changing the oil again right now asap
    I am guessing it's seized or something, and over pressurising,?? I have ordered a new 1 anyway, INA from Greshm
    The UK Forums, They suggest one of these seals
    M26 26mm Mild Steel NBR Hydraulic & Pneumatic Bonded Dowty Seal Metal Bonded Part Nitrile Rubber Bonding viton Sealing Ring also available as option
      You've definitely got the best access to this that you'll ever have with the engine out of the car, so I would replace it. Undo the tensioner, make sure the sealing surfaces are nice (I usually run some red scotchbrite over them), replace the crush washer and reinstall.
      Nah, should be fine to reuse. But make sure you follow the reuse instructions:
Name:	Screen Shot 2022-02-24 at 10.31.45 AM.png
      Well.. I feel like a dummy: for some reason I had remembered reading that the right thing to do when re-installing the TCT was to "prime" it by completely compressing it while submerged in oil, and allowing it to decompress and take oil in. I don't remember where I read this or why it had stuck in my head as correct.
      I recently re-timed my engine, and performed this incorrect procedure that fills the TCT with oil rather than purges it of oil as described in the correct instructions.
      Question is: how bad is this? Why does the oil need to be pushed out before reuse to begin with, isn't it just going to refill with oil during operation?
      Do I need to remove my TCT and re-do this with the correct procedure?
        Still Leaking with new Tensioner from ina and new crush washer.
        i think it's the wobble bit, altering the torque value
        see attachment, so i am gonna ramp up the torque using this chart and hopefully it will stop
          I personally would not go more than 80, clean it thoroughly. I would sand it with 1000 grit to ensure it is as flat as it can be.
            Bump on this, I did not push out oil from TCT before re-install, in fact I filled it with oil. Is this a problem, should I re-do it?
              Bump on this, I did not push out oil from TCT before re-install, in fact I filled it with oil. Is this a problem, should I re-do it?​
              Don't touch it, It's Fine, otherwise it might start leaking like mine
                I think it was a blocked crankcase vent valve, causing the leak, too much pressure ?
                > check this out = https://nam3forum.com/forums/forum/m...ase-vent-valve
