Originally posted by Sid_E46
View Post
Bavsound Review
he upgrades the BM54 to send a better/stronger signal to the hk amp via some tda or similar chip (he scrubbed the part number so I never figured out which chip he used). Sounded really nice on my car. but you are still limited to around 40w per channel from the hk amp. The hk unit uses some Philips chip from ST or something iirc. Could you upgrade them? Probably if you found a chip with the same pin out. Will it give more power or better sound, probably not since you are limited by a 12v system. I personally thought the stock hk amp had a really clean sound if not being slightly under powered.
- Likes 2
For the longest time Bavsound highly recommended not amplifying their speaker kitsOriginally posted by Tbonem3 View PostNow amplify the speakers properly!
Then they ironically teased an amp kit that was made for the same speaker kit
After years of "it's almost there!" promises, they quietly gave up on it
i've made it a point to never buy anything from them since
- Likes 3
I have the Bavsound Speakers and replaced the HK subs with Rockford Fosgate 6x9’s. It takes some slight modding to get them to fit into the housing. The magnet clears the rear deck holes. They sound better than the HK’s, well worth it and only $60. Plus they are 3 lbs lighter than the HK’s. 😎Originally posted by BMWE46M3 View PostDid you replace the subs in the rear deck? As far as I know Bavsound no longer offers replacement subs for the E46. So just wondering your plan if you haven't?
Evolve Eventuri - VIS XTS CF Hood - CF Lip/Console/Diffuser/CSL Trunk
- Likes 12
Yeah, seems like I recall they had some internal small company marketing sorts of issues for a while, which I didn’t attribute to the product. For what they were making, I think they had to charge more than this market was generally ready to pay. As much as I love their Vert product (in hindsight), I was never going to pay MSRP for it (going in). I got lucky and found one on eBay for a number and condition that made it a no brainer. But when you consider the money they saved consumers in product research time, there is really no better option if you want PnP no headache fitment. So that’s kinda been their plight, as far as I can see it. Making products for more cars helped with that, and I really hope they stick it out, make it, and bring back some of those product projects that fell by the wayside, now that they have more financial strength.Originally posted by usdmej View Post
mawLast edited by maw1124; 03-06-2022, 06:58 AM.
What do you do to make them fit? What mods are involved?Originally posted by WOLFN8TR View Post
Regards
These do not fit on M3 Coupes with the rear electric curtainOriginally posted by WOLFN8TR View Post
Just snip the wires going to the tweeters on any coaxial to just use the woofer. Many allow you to just pull off the tweeter as well.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Or, if using a LPF around 80-200hz, just leave it be, as the tweeter won't even be powered. That's if using your own dsp or amp. I don't know if factory h/u or factory amp would send a filtered or full signal to the deck "subs".DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Minor trimming of the plastic around the face of the speaker and slightly enlarging the holes so they line up with the housing. I will post some photos to show what I did.Originally posted by Mr.wReckless View PostWhat do you do to make them fit? What mods are involved?
Regards
Honestly you can't even notice there's additional tweeters in the trunk. These subs sound way better than the HK's, I had to address several rattles from the increased bass.Originally posted by Mayan-Viking View PostThe original 6 X 9 subs are single channel. The Rockford Fosgates pictured above have a tweeter. This would necessarily change sound dynamics if they replaced OEM single channel subs, no?
You can always do what Tyler suggested.
Last edited by WOLFN8TR; 03-16-2022, 05:13 PM.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
- Likes 2
Here ya go…Originally posted by Mr.wReckless View PostWhat do you do to make them fit? What mods are involved?
Regards
Trim the plastic piece on all sides of the screw holes. This will allow the speaker to sit flush inside the enclosure. I used a Dremel with a cutting wheel.
At that point you will see how the holes need to be modified to fit properly. Put two screws on one side and mark the opposite side that needs modified.
All done and ready to install. I used some small washers with the screws beings the holes were enlarged a bit. Also the two plastic push clips rattle with the added bass. I used a hot glue gun to secure them from rattling. For $60 it’s a nice upgrade from the stock HK’s.
Last edited by WOLFN8TR; 03-16-2022, 09:35 PM.TTFS Engine/SMG Tune - CSL 255 - SGT Headers/Sect 1/SCZA
- Likes 6
