Yeah, anyone can have up to 7 different tunes they can swap between on the fly using mssmapper.
S54 Stroker build
In the case of valves, would going Inconel be the best way? I know Ferrea is a well-reputed brand, but how does Supertech fare as well? I'm assuming that stainless steel is the best way to go and not titanium? Would it make sense to have a different valve material for the exhaust side to handle heat better? Finally, oversized valves?Last edited by M/Anthony; 04-23-2020, 06:11 PM.
What is the budget? The DINAN Carbahn 3.3L stroker kit can be had for the ultra low price of 13-15k- https://carbahnautoworks.com/product...ngine-rebuild/
I have not seen many full rebuilds work out well honestly. From memory, Dafoe on M3F had a pretty extensive S54 build with a bunch of coated parts and I believe it had some issue with valve stem seals. And it might have ruined a set of Schrick cams. There was no conclusion to that build. There were also a few other M3F forum members with extensive builds where the threads stopped after a major issue.
I feel like a refreshed stock S54 with cams, csl intake and a full stepped SS exhaust is a great, reliable solution versus building out the internals with a bunch of aftermarket parts. The refreshed setup should get to the ~375whp mark on pump gas.Last edited by Slideways; 04-23-2020, 08:09 PM.
Originally posted by Slideways View PostWhat is the budget? The DINAN Carbahn 3.3L stroker kit can be had for the ultra low price of 13-15k- https://carbahnautoworks.com/product...ngine-rebuild/
But these are S54s and S54 owners we're talking about here. If we were pragmatic, we'd probably own ZHPs.
Partee Racing has the engine builder than built BMW's race engines during the s54 era. If we were doing an engine build, that's where I'd sent it to be done. Carbahn or Lang will likely also get you good results, but IMO Partee is in a league of their own.
I would avoid VAC like the plague. They built an engine for a friend of mine, and used too much gasket maker, clogging a passageway. Their fix, so that they didn't have to remove/disassemble the engine again, was to drill a new oil passageway in the block and then do an oil change to "address" (nope) the oil shavings that created inside the engine. VAC par
The potential for things to go horribly wrong goes up exponentially with internal components other than cams. I like to DIY many things, but I don't think I'd be comfortable DIYing an engine build with anything other than stock parts-- I know just enough to know that I don't know what I should be looking for/checking for as I go.
2008 Black/Black M5 Sedan
Well, we've gone up to 392 whp on 288 280s and 12:1 compression only. A stroker will definitely bridge the gap with the right tune. Maybe even half a point of compression up to 12.5:1 on E85.. Will surely get you there.
Im not a fan of strokers since they cost way too much (factor in the 5k crank) and the s54 is already out of square. So stroking it even more will further skew that, and they don't live that long... Maybe 50k?Last edited by HassanEido; 04-24-2020, 06:12 AM.385.7whp 288.8 wtq :
-CSL airbox ( custom)
-280 272 Cat cams
-Custom SSV2, modified for a bigger collector
-Custom Section 1 2 and 3: oversized to 2.5 inch and en E9xM Xpipe
-TMS pullies
-Electric Fan
-HTE performance Tune :P
PM for performance Tunes
IG: https://www.instagram.com/hte_performance_tuning/
Originally posted by HassanEido View Post...... Im not a fan of strokers since they cost way too much (factor in the 5k crank) and the s54 is already out of square. So stroking it even more will further skew that, and they don't live that long... Maybe 50k?
Before swapping to the Bimmerworld race exhaust (noticeable performance difference) from the Supersprint race exhaust with stock compression, stock rods/pistons, Dinan intake, Schrick 288/280 cams and a EPIC tune, I'm at 356.61 whp and 260.16 foot pounds. I had an intermittent VANOS issue that was recently solved with a new plug as well. I need to get it back on the dyno to see if the numbers have improved with exhaust and VANOS fix. I've got to think some head work, forged internals ($2,500 for rods and pistons), maybe a CSL style intake, balance & blueprint from a quality builder like Partee would get me pretty close to 400WHP.
Feff
Feffman Just run e85higher compression has never been easierπ you'll need a pump upgrade and injectors and a tune (not a fan of piggybacks).
βββββββA csl intake is a must for your goals385.7whp 288.8 wtq :
-280 272 Cat cams
-TMS pullies
-Electric Fan
Originally posted by M/Anthony View PostIn the case of valves, would going Inconel be the best way? I know Ferrea is a well-reputed brand, but how does Supertech fare as well? I'm assuming that stainless steel is the best way to go and not titanium? Would it make sense to have a different valve material for the exhaust side to handle heat better? Finally, oversized valves?Last edited by stash1; 04-25-2020, 09:02 AM.
Originally posted by stash1 View Post
Inconel is used widely in F1 cars, and really unnecessary for probably all but the most extreme NA applications...it's mostly used to handle the extreme heat in FI applications. Ferrea valves are fine as well, and yes, stick w/stainless valves. Titanium isn't needed/necessary or even desirable for 99% of street applications. Use the money saved from not buying fancy titanium/Inconel parts and spend it on quality pot work.
