I finally got my car back on the ground (4 post lift) after installing a VinceBar/CMP Subframe bushings/Turner monoball RTAB's/all new rear OEM bushings.
My issue is the rear ride height looks to be 1" to 1&1/2" higher than before.
I thought I would use the 4 post lift to my advantage when torquing down the bolts for the control arms (to avoid pre-load) but it seems that didn't quite work out.
At first a figured, duh, no differential is installed, no muffler is installed, no rear seat etc., so that must be why the rear end looks jacked up like a muscle car, due to the missing weight of those components.
I installed the muffler and then hung 100lb of weights from the subframe to simulate the diff./brakes with a negligible effect.
All of my bolts (inner/outer - upper/lower control arms) where simply hand tight when I let the vehicle down off the jack stands and onto the 4 post list, so presumably no bushing pre-load was present.
The only bushings that may have preload are the Turner RTABs as you cannot torque them to spec once the toe plates are installed.
Any ideas? My springs seem to be seated properly..
EDIT: Unfortunately I did not take measurements of my fender to wheel relation before taking things apart but I have many photos of the car before disassembly plus I simply remember how it looked.
Is is possible the shocks got stiff after 1+ months on jack stands? I know I am really reaching there.
