Ride height changed after CMP/Vincebar
    Could also be that the brake caliper pistons havent settled into position. Recommend a few hard stops to seat all the pistons.
    Yep, this is the first thing I thought of. Also, rotor might have developed some slight surface rust from sitting for a while, which could be making noise against the pad.
    Put the car back together fully, drive it hard and then check for any weird noises.
      I’ve got poly subframe bushings and hear a lot of differential whine. Those look like solid bushings and if so I’d imagine it’s worse with them.
        It might be your diff bushings amplifying the diff whine.
          Nope. I came from poly to solid and if there is a difference I can’t hear it. I have oe diff bushings.
            I went with CMP/Turner RTABs and OE everything else in hopes of very limited NVH penalty.
            I really think it's a slightly locked caliper(s), hope to drive more this weekend and see if the sounds lessens, all interior is installed save the trunk carpeting/floor, I will make sure these items are installed before coming to any judgement.
            Just seems like CMP bushes and Diff. whine are not a synonymous thing from what I understand, not to say it can't happen.
            I never had diff. whine before that I could hear.
            I did re-use my diff. fluid fwiw, sucked it out with a big syringe so I didn't potentially loose any when I did the seals.
            Put it right back in with the syringe when the diff. was back in car, only had to add about about ~2oz. if that due to spillage.
              Probably true, I forgot they’re poly as well. Whatever it is, I regret it.
