Coils: Delphi or Bosch? Other?
  • bigjae46
    Originally posted by prostcfc View Post
    I bought these this year from FCP. No issues and car runs great.
    Also made use of a screwdriver through the holes to pull out a stuck unit.
    Installed plugs and coils sans lube and used an inch-lb torque wrench.
    That's what I do.
  • prostcfc
    It will fit. The same part was used across a lot of different platforms beginning 2003. LCI E46 330s changes to this coil.
  • skylinekin
    If coil won’t pull out by hand I just use a screw driver shaft thru the hole in the locking clip to pull it out.
    Personally I prefer no dialectic grease but if you do put only a very thin coat inside the boot tip avoiding getting any on the end of the spark plug. Also reminder no anti seize on the plug threads!
  • WoGGo
    Anyone using a special tool to remove the coils, if so, which one?
    Dielectric Grease.. required, or go in raw?
  • WoGGo
    part number for 273 ELDOR is NLA
    I found NOS here in Australia if anyone still wants to run ELDOR from a BMW box
    Is the ELDOR part number still the same ? or have they changed ?
    I may need new coils... link to the NOS Eldor coils you speak of?
  • 0-60motorsports
    Elder or Bosch
  • sapote
    These are the best coils for E46 cars. Unfortunately the M3 can't use them. They were used on early cars.
  • 9kracing
    Carbahn makes them now too if you prefer Steve over Holley
  • bigjae46
    Waking up - FCP sells that Eldor part number coil, but does not show it as fitting the S54: https://www.fcpeuro.com/products/bmw...657273#fitment
  • BlueBimmers
  • BL92
    Found the Jelly Bean Coils on mine, Wish i payed more attention the last 5 times i had them out comp testing and doing the head gasket
    Found a old 260 coil from 2007 with E46 on it (must of been from a junk yard )
    Some Bosch 08s
    A Bosch 2015
    A Bosch 2019
    Seeing this is some serious motivation to swap them out
  • BL92
  • Shonky
    I wouldn't have reservations against using them.
  • BL92
    These ones ok?
  • oceansize
    I installed the Dinan's a few months ago after one failed, no problems.
