wtf.... Diff OIL, can't find a FM Booster
Budget CSL MAP Conversion
Only reason I didn’t follow this was there was only anecdotal evidence that this combination yielded the bmw factory formula.Originally posted by COVID-19 View Post
Since the castrol by itself is made for LSD there has to be some FM in it already. And as we know Castrol is known to change formulas over time without changing product labels (i.e. 10W-60 TWS is not the same formula as Edge Supercar but compatible)
I don’t think you can go wrong either way. Plenty of folks just run Redline with no FM and haven’t blown their diff up. If you ask Bimmerworld they recommend straight Redline with no FM (would not recommend).
The oil I took out was pink/purple - not sure what the fuck it was but it groaned alot in slow speed full lock. The straight Castrol Syntrax is quiet.
Agreed for a street car.Originally posted by 01SG View PostCounterpoint: Given the importance of the differential and the infrequency of changing the fluid, it is worth skipping the hassle and getting the factory stuff that is already measured perfectly.
Different for a track car that changes the fluid more often. The fluid takes a lot more heat and wear so it needs to be changed a lot more frequently. Keep in mind more FM results in less lock up which might not always be a bad thing.
That would be too easy.Originally posted by 01SG View PostCounterpoint: Given the importance of the differential and the infrequency of changing the fluid, it is worth skipping the hassle and getting the factory stuff that is already measured perfectly.
You will indeed need three bottles. It takes about 1.2 liters.
https://www.fcpeuro.com/products/bmw...SABEgJDUPD_BwE
Remember, people like to struggle.2003.5 MT JB/B - CSL SCHRICK SUPERSPRINT EISENMANN JRZ SWIFT MILLWAY APR ENDLESS BBS/SSR DREXLER KMP SACHS RECARO AR SLON MKRS GSP DMG KARBONIUS CP AUTOSOLUTIONS KOYO
Lest we forget, E46 M3s only came in to get the FM booster if the owner complained about noise. The SAF XJ is already a LSD specific fluid. I'd rather have some noise, and solid lock up than no noise and more slip, as I've said in previous diff fluid related threads.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
+1Originally posted by Tbonem3 View PostLest we forget, E46 M3s only came in to get the FM booster if the owner complained about noise. The SAF XJ is already a LSD specific fluid. I'd rather have some noise, and solid lock up than no noise and more slip, as I've said in previous diff fluid related threads.
I haven't run FM for 45k miles. No noise, no chatter, no I'll side affects. While I used FM before, I haven't on this diff.
Granted, I have changed the fluid 3 times in those 45k miles for various reason, but the fluid is always cleaner than I expect.Build thread: Topaz Blue to Shark Blue
I followed this as well. I bought the friction modifier from a local ford dealer for 8$. And I used a cooking syringe to measure it out. So far so goodOriginally posted by COVID-19 View Post
How is it now that it's been a while?Originally posted by eacmen View Post
Do you have a source that suggests this stuff has FM in it? I just put this in my diff and am now discovering all this nonsense.
I sorta just trusted FCP since they had it and they typically weed out the stuff that isn't quality, but now it's actually not available anymore.
Works great for me.Originally posted by bavarian3 View Post
