Use a good sized screwdriver to gain a titch more clearance between each rotor and dust shield.
Brake Rattle Over Bumps
Yes.Originally posted by eacmen View PostShot in the dark, you have these clips installed on the caliper right?
https://www.fcpeuro.com/products/bmw...-34211157046oe
I just checked TIS and you're right. Front bolts are M12 and rear bolts are M10. 81 ft lbs for the M12 bolts and 48 ft lbs for the M10 bolts.Originally posted by thetypicalm3guy View PostInteresting, where did you find 48 ft lbs? Everywhere I looked said 81.
I think the torque spec pdf originally said 81 for all and then was updated. Now it says 48 for both. I'll fix it soon. Damn, I should also go double check my car. Apologies for the confusion!2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
This should not be happening. The pads ride in the abutment clips in the caliper carrier bracket. The pad ears should be a snug fit into those clips. If there is play then its likely a manufacturing tolerance issue with the Jurid pads.Originally posted by thetypicalm3guy View Post
It is not the dust shield, I believe it is the inner pad ears hitting the caliper.
If you got from fcp might be worth trying a different brand.
It fits snug on the outer side not the inner thoughOriginally posted by eacmen View Post
