It's smog week for me in CA, and I got cocky tonight and threw myself into doing the swap without carefully researching how to undo the DME wiring modifications. I have a MAP sensor and IAT was done using one of those adapter harnesses that just plugs into the MAF's harness connector.
Stock box is back in and all mechanicals are back in place, MAF sensor plugged in, and old non-CSL DME is back in place, but car won't start. Cranks once and dies.
I'm guessing is that there's some wiring I have to restore, but I'm scratching my head as to what. The IAT adapter harness is removed, which leaves the MAP. If I recall, the MAP is wired in by splicing into two existing wires, and then the third gets added to a pin on a DME connector. Shouldn't just unplugging the MAP sensor be sufficient to undo this? If all three wires are dead/unplugged from the MAP, it doesn't matter that they're still spliced/pinned in right?
Any sanity checks here would be appreciated!
