2006 M3 seems to have RACP reinforced from factory
    I am aware this has been discussed many times and the consensus is that all cars are prone to cracking. I was about to fill my cavity with structural foam when I ran an endoscope inside the cavity of my 2006 M3, and I found something unexpected.
    According to BMW's service bulletin to address the RACP, there should be one hole on each side and you'd have to drill one in the middle. Mine already had another hole, offset towards the driver side. This got my curiosity: "is it a coincidence that BMW drilled another hole closer to the side that's prone to crack?)
    Click image for larger version  Name:	IMG_2477 copie.jpg Views:	0 Size:	184.8 KB ID:	179684
    Fig 1. Offset hole and reinforcement plate.
    So I took my endoscope and looked into the cavity from the second hole in fig. 1. I found out that the space that the tis bulletin advises to fill with structural foam was sealed off from the right side of the cavity by a large metal plate that seems to be epoxied in. I tried to illustrate what I found beneth in fig. 1 in red: the metal plat seals off the left side from the right side, and extends towards the RACP mounting points. The bend in the plate has reinforcement which seems to indicate that it is a structural part.
    Click image for larger version  Name:	Photo le 07-08-2022 à 18.51.jpg Views:	0 Size:	209.3 KB ID:	179685
    Fig 2. Metal plate inside the cavity, seen from hole 3 following the eye symbol in fig.1, the picture is upside-down. Some epoxy (blue) seems to be fixating the plate to the body metal.
    Click image for larger version  Name:	Photo le 07-08-2022 à 18.48 #3.jpg Views:	0 Size:	171.1 KB ID:	179686
    Fig 3. The plate (in black) seems to have a structural design
    Click image for larger version  Name:	Photo le 07-08-2022 à 18.49 #2.jpg Views:	0 Size:	174.7 KB ID:	179687
    Fig 4. The plate is also screwed in the top (the "roof" of the cavity where the RACP is mounted)
    Click image for larger version  Name:	IMG_2479.jpg Views:	0 Size:	67.5 KB ID:	179688
    Fig 5. Photo taken with phone from top of hole 2 showing the plate (in black) and the epoxy that seems to fixate it in the cavity (blue). This photo is also showing the bend and how it looks structural.
    Very interestingly, this only exists on the driver side. There is no such plate on the passenger side.
    What are we looking at here? Anyone has seen this before? I don't mean to spread disinformation or rumors, I'm just curious and this seems to be reinforcing the RACP. I had never heard of this before. I heard about additional spot-welds in 2001+ models but nothing like this. I know that older cars (2003 for example) don't have this. Would this be a late review of the chassis by BMW?
    My car, a 2006, has seen a few track days and some hard driving and shows no sign of failure, including no popped spot welds or apparent hairline cracks (I have not removed the subframe to look under the bushings).
    Click image for larger version  Name:	IMG_2475.jpg Views:	0 Size:	99.4 KB ID:	179690
    Cheers,
    05 and 06 cars, both ZCP and non-ZCP, have that 3rd hole. I just verified on an 06 ZCP, a friends 05 non-ZCP, and an 04 (which did not have the 3rd hole).
    Redish has posted an in-depth video on YouTube - I’ll try and find it for you.
      It's plastic actually
        Nice! So those who welded plates on 05-06 must have melted a part of this... :/
          Part of the reason why, IMHO, if you’re going the plates route you’re better to use structural epoxy to bond the plates than weld.
          2005 ///M3 SMG Coupe Silbergrau Metallic/CSL bucket seats/CSL airbox/CSL console/6 point RACP brace
          Build Thread:
            My 08/2004 build doesn't have the third hole (so agrees with that video).
              That’s why the Service Information Bulletin told dealers to replace whole panel from 10/04 up E46 models instead of doing the epoxy foam. Because they had that plastic block there.
              The prior to 10/04 builds with cracks at left mount 20 mm or less got the epoxy foam fix.
                Bumping this thread after having re-read the SIB for the cracks and since I'm curious how to--if at all--address my subframe carrier panel. I have a 12/2002 build, no cracks, no foam, totally stock. If I read correctly, seems the foam is NLA. What would be my best course of action to prevent cracks? Car is not a track car, spirited drives, but nothing hard. I had thought to go ahead and do the foam as a reasonable method of crack prevention.
                  There is another epoxy foam you can still use.
                  Is that going to be enough for some chassis’ to prevent cracking is the question. And yes for some, no for some others.
                  “Best” course of action to prevent cracks, is probably top mount bracing, front cup addition along with bottom plates. That’s if you want to “bullet proof” it. That’s also the most expensive and labor intensive.
                  Could you just do bottom plates and be safe after all this time with current driving style..I would say likely.
                    Good intell, thanks.
                    Interlagos 06 M3, Autologic tune, Agency Power midpipes/exhaust, Fortune Auto coilovers, UUC SSK, Bluebus, Lightwerkz retrofit. MRegistry listing here
                      Mine 2006 still cracked.
                        Are you going to replace the whole RACP panel or just try to fix this??
                        GT4 Composites
                        2003.5 BMW E46 M3 Laguna Seca Blue / LSB 6mt
                        2006 BMW E46 M3 Estoril blue / Black 6mt
                          I try to fix it.
                            Cracks welded and bottom plates installed. Next step - top reinforcement
