do anyone know what's the tool to look for to test the SMG pressure accumulator when it's off the car?
was browsing around on ebay and amazon, searching for the tool to test "nitrogen pressure accumulator" ..
but not sure which is the cheapest, most effective and easy operation one to get ~
have a spared part for like over 5 years~ not sure if it's still working well, and it would be a big PITA to find out the hard way after i put it onto the car ..
thank you~
by the way,
can SMG owners or experts who can help to share some insights as well~
symptom:
- car drops out of gear for period of time
- lost gear, shows N
- cruise for a while (suspect it's building back pressure)
- pops back to same gear, or lower gear #, car's back to motion and in control
- drive for a while, drops out of gear
- cruise for a while, back to gear and repeats
background1:
- car was having other gear issue, changed with used GPS and gear actuator (in pair)
- drove fine for a very short time, then new symptoms happened
background2:
- 2002 m3, old pump, old motor, new salmon
- slave cylinder changed for like 2 years ago ..
discovery:
- when doing inpa bleeding, notice high pitch hissing sound ( so i assume it's leaking somewhere?)
- when key in, dash shows N gear much slower than before (so i assume, either GPS is acting up or pressure is not there quick enough to detect gear)
- SMG oil level is not really dropping (last time i checked)
am i on the right track?
my plan is to lift up the car,
(1) run inpa bleeding, and see if i can spot the "leaking spot" or figure out where the hissing is coning from first..
(2) change out pressure accumulator from the donor pump
thank you~
by the way,
symptom:
background1:
background2:
discovery:
