  • Cubieman
    Is buying the double sided sticky tape required for reassembly? I see the 3M product has is it and it is not used per the 1st video, but do you need it for the other OE piece to go back on correctly?
  • Inizes
    I used the 3M, bought it off eBay. See post 1 to see everything I’ve seen people say they have used.
  • SGM330
    Originally posted by andyitslit View Post
    Did my driver side this past weekend with the Metro weatherstripping. I got a big kink but I'll go back in and stick some vacuum line in there.
    I did this a long time ago on my old E46 and it turned out much better but no way I remember which weatherstripping I used. The metro one seemed too soft.
    I'm having the exact same issue with the Metro weatherstripping. Vacuum line didn't help. Any other weatherstripping that is recommended that can be ordered online?
  • andyitslit
  • Dafoe
    YES, I am JUST in the middle of planning this fix on my drivers side window. Thanks OP.
    This should be added to the DIY thread, if not already.
    Cheers everybody!
  • DiscoWagon
    Big thanks to this thread as well as the video references mentioned. Just tackled this last week, plastic razor blades definitely make the job so much easier. I used Adam's TAR to remove the adhesive which worked like a charm: https://adamspolishes.com/products/adams-tar
ID:	15605 Click image for larger version
  • Albino09
    Regarding the adhesive for the side trim: this came up in the previous version of this DIY on m3f.net. Someone in there suggested 3M General Purpose Adhesive Remover and some plastic razor blades. The key is to begin scraping while the old adhesive is still wet with the remover. Within a couple seconds of soaking, it comes right up. Make sure you clean the area after you're finished in the case any remover may still remain on your paint.
  • mugm3
    Finished the side finisher pieces today. I am usually one to just go for the go fast goodies but going a different route with this car. I love how bmw has made it like legos and that you can rebuild the whole dang thing. The adhesive tape on these wasn't as bad to take off as the rear side window trim. I used a heat gun again and peeled off with my thumbs.
  • ///Mac
    Originally posted by see.m3.go View Post
    What have you guys found works best for removing the adhesive? Goo Gone does not seem to be cutting it.
    Coincidentally I did the finisher seal repairs and horizontal seals last weekend without seeing this DIY. Wish I read this first as it would have eliminated some guesswork.
    To remove the adhesive left by the horizontal trim I tried bug&tar remover, alcohol, Goof Off, and finally Wax & Grease Remover. The wax & grease remover was by far the most effective, but it still took several applications and passes with a plastic scraper to get it off. I also used a heat gun and that helped soften it up.
  • mugm3
    Just tackled the rear side window finishers today. Took about 4 hours total. What a pain in the arse. I used a heat gun and lots of adhesive remover along with a plastic scraper. Next up is tackling the side finishers.
  • Bostonbruck
    Starting this DIY today. Thought it was a good time to tackle this since I shipped my steering wheel to Cobywheel.
  • T-Rex
    I got through the driver's side of this repair yesterday in 5.5hrs - going to tackle the passenger side today. It appears you didn't pull the rear window seal off entirely - that was smart. That was a complete bear to put back on!
  • netcsk
    I did mine last year using the seal available locally from Advance Auto. Installed picture is about 7 months after install.
  • Inizes
    I am SOOOOOOOO happy that you got the "double-sided sticky tape" guy's video (the first one). I missed him...
    Honestly I didn’t even notice in the few times I’ve seen it. He does say it a lot lol. I like the video as it gives some good visuals to parts that I didn’t take pictures of.
  • mrgizmo04
