Just in case no one was tracking the Bimmerworld box is built by the same guy who made all the CF parts for PTG.
Haimus vs Karbonius Race vs Karbonius CSL airbox
Originally posted by audipwr1 View PostThe haimus boxes are ready to ship now and Karbonius is 4 months out
Did folks go with the premium or premium+ gloss finish?
I emailed to ask as it wasnt clear but what is included in the Haimus package? The OEM parts too or just the intake?
Also newb question - why cant I post in the WTB parts section?
Haimus is about to release a new "Shadow" trim level, essentially all CNC'ed parts will be gloss black. They've also improved their mold to have easier OEM filter fitment.
I can help you towards a box directly with Haimus here.
My 07MAR23 build Karbonius Race airbox. I’ll reach out to ECS on Monday to see if I can exchange it. If they give me issues, I’ll just reach out to Karbonius.
Yes, the pins underneath are lined up correctly. Also, don’t these intakes come with an M Power decal? It appears that someone opened up the box and the envelope to remove the decal.
Originally posted by Slideways View PostAre you pointing out the alignment between the two pieces?
Yes, it typically comes with the warranty information and a decal.
Yup, the last tab doesn’t line up. And sucks that someone took the decal out wtf.
They should be able to send you another one.
Originally posted by SQ13 View PostMy 07MAR23 build Karbonius Race airbox. I’ll reach out to ECS on Monday to see if I can exchange it. If they give me issues, I’ll just reach out to Karbonius.
I have shown my colleages and they said these clearances are within normal tolerances and do not affect the performance of the airbox
Even the original CSL airbox bmw has similar clearance. The two parts do not need to be hermetic, the important thing is that the part of the filter does not have leaks
Anyway, and that said, if you are not 100% satisfied with piece, you can of course send us back and we will refund you money paid (except for shipping costs)
Just let me know and I'll tell you what to doLast edited by SQ13; 03-22-2023, 06:12 AM.
It does not look too bad to me. Look normal tbh. I understand your frustration as these things should literally be perfect for the amount they command.
my OE style Karb had flushness issues, I was worried as that variant does need to be air tight, but despite the fit concerns it is air tight and is not causing any issues and once install only you will know is there.
Have to put some force on the tab to get the holes to line up. Im just worried that it’ll crack if I use it like this.
Is the ICV port beveled on the inside of the box? The newer ones should be, albeit, not as smooth as the original CSL. The Karb airbox used to not have this and they would whistle at part throttle under 3K rpm. The solution was to use a dremel and give it a smooth radius for the air to enter the port.2002 TiAg M3 Coupe (SMG to 6spd), 2003 Jet Black M5
Originally posted by SQ13 View PostHave to put some force on the tab to get the holes to line up. Im just worried that it’ll crack if I use it like this.DD: /// 2011.5 Jerez/bamboo E90 M3 · DCT · Slicktop · Instagram
Check out my recent journal entry where I had to enlarge one of the holes. Not a big deal imo. Use a rat tail.
Edit: Did you use a hand rat tail file to elongate the hole, or did you use the drill attachment to open it up evenly?Last edited by SQ13; 03-22-2023, 09:21 AM.
