When removing Caliper, what should be used to cap the line
    When removing Caliper, what should be used to cap the line?
    Would you recommend against the clamps on the brake line itself?
    Vacuum plugs over the line ends do a good job of containing brake fluid leaks
      I use a Schwaben fluid line stopper kit.
        Vacuum cap that fits tightly. I wedge a short 2x4 between the seat and the brake pedal to keep the brake pedal ever so slightly depressed. No drips, but I still use a vacuum cap.
        And no, I would not clamp a brake hose.
        Old, not obsolete.
          I am going to give this a try: Didn't know this existed before
            Nice find. May just grab a set myself.
            Old, not obsolete.
              I made caps myself, very practical when you play a lot with these cars.
              I cut the rubber from old brake lines and weld/plug the make caps, see picture:
                Vacuum caps w/zipties, locally available and definitely work.
                  I need this in my life.
                    Yes it’s super practical when you want to swap brakes from one car to another or if you want to paint your calipers as a winter project or send them to powdercoat.
                    Just need old brake lines or the cheapest one at local auto parts!
                      A few more options. https://www.jegs.com/p/JEGS/JEGS-AN-...52564/10002/-1
                        If you are replacing the rubber line, pinch it somewhere towards the body connection. Then cut the line in half (between the pinch and caliper) and screw a 5/16" sheet metal screw into the body side opening. Once you replace the line keep this old piece to screw on if you aren't replacing the lines in the future.
                        *edit, this will be secure enough that the car can be moved and still have some brake pressure. There are more than 1 cars kicking around my shop that have a pair of calipers removed but still functioning brake pedal.
                        Email to [email protected]
