Hello All, and thanks in advance for any help you can provide.
Vehicle is a 2002 325i. Not an M, but others on here have said I should be okay coming in here.
175k miles.
This car is currently in limp mode, w/ the amber trio of EML/DSC/Brake lights on the cluster lit up in amber.
I scanned w/ OBD Fusion and came up w/ P1632 - Throttle Adaptation?
I can clear the code w/ OBD Fusion, but then when I simply cycle the key to ON (not start), the amber trio is back.
I broke out the Schwaben tool, w/ BMW module on it and came up with the 5E19 Present - ABS-DSC: CAN data fault from DME/DDE. I cannot erase this with the Scwaben tool.
I do have INPA, but I am not very familiar with it. I will plug that in and scan next.
Any helpful hints to start with?
Thanks all!
175k miles.
Thanks all!
