Reinforcement Plate Bolts Question
    I believe that last time I removed the reinforcement plate to do the rod bearings I had to change the bolts as they were one time use only. Is this correct?
    I have a slight leak that I cant figure out where its coming from and will probably need to remove it. Want to make sure I dont snap any of them if I reuse them as I think the torque spec on them was pretty high.
    Thanks!
    You won't snap them if you reuse them and they were torqued correctly previously (and a lot of people do). However, BMW does specify to replace them after every use.
      If you replace them I'd suggest getting them at FCP since they have a lifetime warranty, and you'll never have to buy them again the next time you need to remove the reinforcement plate.
        I recently re-used mine. Torqued to spec, sans the angle. So far so good. I do have a fresh set for use after I do some exhaust and front end work, as I won't (shouldn't) be back in there again for a while.
          Yep, properly torqued with SnapOn torque wrench that has angle as well.
          I knew there was a reason I replaced them, I guess I read them in the BMW instructions I had for the bearings. '
          Will try and reuse them. The FCP euro is a great idea!, as a matter of fact I need to check as I might have bought them there.
            I mean, if you did not do the angle part you are extremely undertorqued ... might as well tighten them without a torque wrench, no?
              Given the application, I’m comfortable with how I’ve installed it.
                I snapped one before, also reused them before. Since it is a reinforcement plate, I would do the proper torque angle on it, it is considerable amount of additional torque and with how anal we all are with rigidity/handling and such, I wouldn't skimp on a reinforcement plate. Ymmv.
                  I rotate in 2 or 3 new ones each time.
                    Probably a good idea. I just checked and they are $40 from FCP Euro. Last time I removed them was about two years ago, I will just wait another week to check the car and order them.
                    I wonder if they are stretch to yield bolts.
                      You go to Penn State for Engineering?
                        I just run these in with the impact, never broke one or had any issues. Some of you are seriously overthinking this.
                        I think only once I did the proper procedure with a SO digital torquewrench, it came out to a final torque of around 100 Nm (might be wrong it's been a few years).
                        Which to me seems way too low to reach the yield point of a bolt sized like these, so I would deem them totally fine to re-use.
                          My Bolt did stretch, I’m gonna buy new ones from FCP.
                          ‘04 M3
                            My 330ci was missing a couple bolts. I grabbed a couple at the local scrap yard from another e46 but they wouldn't bolt in. I believe they were stretched. I picked up a couple new ones and they fit fine. I guess it all depends on how much torque is used will determine if they get overstretched.
                              A couple of ugga duggas on the impact.
