I believe that last time I removed the reinforcement plate to do the rod bearings I had to change the bolts as they were one time use only. Is this correct?
I have a slight leak that I cant figure out where its coming from and will probably need to remove it. Want to make sure I dont snap any of them if I reuse them as I think the torque spec on them was pretty high.
Thanks!
Thanks!
