Originally posted by x Spades x
Valve bent, piston indents... :-(
If you had the crank locked at TDC1 and the cams set up with the bridge you would be OK. But what is to keep the properly timed cams from spinning due to valve spring pressure when bolting them down creating this potential issue OP experienced?2004 Silbergrau Metallic 6MT
Originally posted by Cubieman View PostIf you had the crank locked at TDC1 and the cams set up with the bridge you would be OK. But what is to keep the properly timed cams from spinning due to valve spring pressure when bolting them down creating this potential issue OP experienced?
I assume another wrench on the cam to hold it in position. I'm about to install my head too so now I am curious how to go about it without the cam tool. Maybe I just get the cam tool...2004 Silbergrau Metallic 6MT
Honest mistake, sorry this happened.
TIS will state when doing something like this you ALWAYS back the crank up 45*, this will lower all the TDC pistons enough to not have contact with valves in case of a misalignment like the OPs. Once everything is tightened turn the cams to the TDC position and THEN move the crank back to TDC.
*Edit, like others stated, knock the high spots of the piston with a file and run it. Be sure to catch the debris and honestly if the engine is on a stand turn it upside down while you do this.'00 R11S, '09 HP2S, '12 R12GSA, '00 Gray 332iT (SOLD), '00 Black 323iT, '02 Alpine 325iT (Track Wagon), '02 Japan Rot 325iT
Can I lap two exhaust valves from an old engine, if new valves aren't available?
Will they seal as well?Last edited by x Spades x; 10-24-2022, 09:59 AM.
My wife ran her 325iT with no coolant and cracked the head twice. On both times I bought the used head on eBay and both heads had leaking valves from collecting debris/corroded on the valve seats (checked with gasoline in the combustion chamber) . I lapsed the valves and fixed the leak, without removing cams + springs + valves.
That’s a bad one. You should be able to smooth it out as it was constant force that did it and not an impact. I once did a head on a car that broke a T-Belt (2.0 VW) and the piston straight up disappeared while doing a wide open test drive. On an M54 on a lower output engine I’d say this is ok-ish, but on a 8k rpm Motorsport engine this is beyond my comfort level. I may have some stock used piston that you can have, will look.
Ok so trying to take out the bent valve and running into an issue. So the valve is stuck almost all of the way open (spring just about fully compressed). How do I get this out? Usually you can compress the spring enough to take out the keepers and tge retainer pops off and everything seperates. I guess the valve is bent higher up on the stem?.
So this where you need to use a lot of caution. Bending the valve back may damage/crack the end of the valve guide. The valve guide could already be damaged if the valve is stuck all the way open and the stem is bent that much. It's going to be tricky to remove the valve without damaging the guide. I knew someone that this happened to as well and the valve guides got damaged by bending the valved back enough to get the keepers off.
Originally posted by AdamM3 View PostSo this where you need to use a lot of caution. Bending the valve back may damage/crack the end of the valve guide. The valve guide could already be damaged if the valve is stuck all the way open and the stem is bent that much. It's going to be tricky to remove the valve without damaging the guide. I knew someone that this happened to as well and the valve guides got damaged by bending the valved back enough to get the keepers off.
if I damage the valve guide, are they easily replaceable?
