Originally posted by snaponbob
S54 Dyno Database
I started posting up a comparison graph, but realized that your torque numbers are actually pretty comparable to a similar vehicle above 3,500 rpms. (The bell shape of your curve was throwing me off-lol.) Under 3,500 rpms though, your torque falls off of a cliff...that's a characteristic of a large single pipe set up. A traditional well tuned twin-pipe set up will hold a pretty flat torque from just above 2,000 all the way up to red-line. I think my car was down around 50 ft. lbs. under 3,500 rpms...and that was w/tuning. Ha, it's an ok state, if you can avoid Baltimore City...think we're like #2 on the murder rate hit list now-UUGH!Last edited by stash1; 02-08-2022, 08:46 AM.
Thanks for the input. It IS a single pipe system. When I detailed the specs to Karl, that was included. And I agree with comment about track use. Not sure if you saw the dyno trace I post a day or two ago, but the torque curve is nice. There is another dyno printout earlier in this thread that shows a REALLY flat curve from 2500 so I was curious about that.Originally posted by stash1 View Post
The answer to your question is simple: it’s been proven by many (myself included), and many times over, that a single 3.5” pipe kills bottom end torque. You can compensate somewhat w/cam timing, but you will never get all of the low end torque back. Your tuner of choice should be able to compensate a bit for the single pipe. But I know many track guys prefer a single pipe for weight savings, and most track cars spend the majority of time over 4,500rpms…sooo, low end torque typically isn’t as critical on a track car vs. a street car.
I had a 98 M3 that I modded in a similar fashion. It had a 3" single system with a single 100 cell cat. Never dyno'ed it, but it was stronger than other similar M3s I worked on. I did barrow a similar 2.5 single system form an E36 325 that I had installed. I could really feel the power loss. I can't imaging a 3" single system flowing better on an S54 than a 3.5" single system. After all, Bimmerworld sell single pipe race systems for both E36 and E46 M3s, and they are 3" and 3.5" respectively. Not taking sides on the debate, but I tend to think they know what they are doing given their racing experience.
BTW, I miss living in Maryland SOOO much.
The answer to your question is simple: it’s been proven by many (myself included), and many times over, that a single 3.5” pipe kills bottom end torque. You can compensate somewhat w/cam timing, but you will never get all of the low end torque back. Your tuner of choice should be able to compensate a bit for the single pipe. But I know many track guys prefer a single pipe for weight savings, and most track cars spend the majority of time over 4,500rpms…sooo, low end torque typically isn’t as critical on a track car vs. a street car.Originally posted by snaponbob View PostThe tune is from Active Autowerks and are usually quite good. I have e-mailed them the charts to see what they think.
That said, I saw some earlier NA S54 dyno plots from similar setups as mine showing substantial torque coming in at rather low rpm. I wonder how that can be achieved.Last edited by stash1; 02-07-2022, 06:59 PM.
The tune is from Active Autowerks and are usually quite good. I have e-mailed them the charts to see what they think.Originally posted by stash1 View Post
Good HFC's only cost around 5HP vs. no CAT's, and a good custom tune is probably worth another 5-10HP max over a decent canned tune. Thanx for posting up btw!
Yes, depending on class. Stock is stock, Street Tune allows alternate cats (no less than 100 cell) but no further that 6" down stream from the original outlet. Higher level classes do not require cats. Euro would not be allowed as only US spec would be allowed. No such restrictions are in place for SCCA or NASA Time Trials.Originally posted by Slideways View Post
Does SCCA care where they are located? On the E46M, the best place for them is downstream in the section one like the Euro cars.
Does SCCA care where they are located? On the E46M, the best place for them is downstream in the section one like the Euro cars.Originally posted by snaponbob View PostFirst post into this thread. The questions will be opinions on the cost effectiveness of remote tuning vs a good drop in file, and what could be expected if good CATLESS headers are installed.
The car --- 2004 M3.
WPC bearings, full rebuild of the VANOS except the drive plate for the oil pump, valves adjusted.
Compression is 175-177 psi front to back. Leak down is 8%-18% depending on the cylinder.
New NGKs, new coils, new injectors.
No oil consumption. Three good Blackstone tests.
EVenturi CAI, triple underdrive set, fan clutch in place.
Drop in tune from Karl at Active Autowerkes.
Stock exhaust manifolds, except I cut out the OEM cats and grafted in same physical sized 100 cell cats. (SCCA Solo STU requires cats) I will never EVER do THAT again. NOT easy. Exhaust is a single 3.5" system with two resonators (as only one was skull crushing loud).
Dyno chart attached.
No dyno was done before the mods.
NO AFR was done as this dyno session was only for the purpose of SCCA Time Trials classing. This year will be running NASA TT so there is some room for some added power.
Good HFC's only cost around 5HP vs. no CAT's, and a good custom tune is probably worth another 5-10HP max over a decent canned tune. Thanx for posting up btw!Originally posted by snaponbob View PostFirst post into this thread. The questions will be opinions on the cost effectiveness of remote tuning vs a good drop in file, and what could be expected if good CATLESS headers are installed.
NO AFR was done as this dyno session was only for the purpose of SCCA Time Trials classing. This year will be running NASA TT so there is some room for some added power.Last edited by snaponbob; 02-06-2022, 06:39 PM.
I've never been around a mustang dyno but we used to dyno a lot on old claytons, don't know if anybody remembers those. If I had to guess probably the easiest to fudge which is why I appreciate the dynojet in addition to it's single roller.
You could get wildly varying results from that by simply varying simple inputs, but that was a long time ago and the details are foggy.
Also I've been saying this whole time there's something wrong with duracels car, 340 is low for the mods and power band is strange.
anyone have a dyno plot from a super flow dyno and then DJ the same car? Just wondering what the delta is between those two.
T
Cool, GL, and post up after the dyno! FYI, numbers on a Mustang are virtually meaningless. The operator can 'scale' a Mustang dyno to read either high or low, but the vast majority try to 'approximate' Dynojet numbers because that is the industry std., and also because they don't wanna lose business to 'higher' reading Dynojets.😁 I've actually seen some higher numbers from a Mustang vs a Dynojet before...it's a myth that Mustang's automatically read lower. Def try to get back up numbers on a Dynojet (but not EAS's😉), and I bet that they're within just a few HP of the Mustang.Originally posted by thegenius46m View Post
Yeah he’s also barely making power past 7.5k which is not right. My buddy made 330whp on stock head, cams, evolve airbox, and fab speed catless headers on a mustang dyno on 91 on a 100 degree day.
Will let you guys know what I make on Saturday with the following:
-Stage 3 head with single groove supertech valves and springs
-schrick 280/272 cams and dlc followers
-Full SS exhaust with V1 stepped headers, no cats
-Karbonius Airbox with CSL Map and DME base
Hassan has told me he has made power on a stock engine up to 8800rpm with my cams so I am planning to have him tune to that just to see because the head will take it. If we make power I’ll drop it down to 8600rpm and just plan to replace bearings every 50-60k miles. Nbd lol.
Block leak down tested to only 1-2% loss across all cylinders at 126k miles which is incredible so really looking forward to this.
Will be using a mustang dyno so the numbers will definitely be lower, probably high 340-350 range so I plan to get on a dyno jet at a later time for the actual comparison here since most guys are using dynojet as a reference.
