S54 Dyno Database
  • jet_dogg
    I don't think he'll dyno that high.
    My advice, set your expectations low and if you're surprised then all the better.
  • EthanolTurbo
    Originally posted by fullyflaredd View Post
    Lol the PO of my car installed a Lang stage 1 head and I just read all the posts about his work. Now I'm worried that there is something wrong with the head, but I guess I'll find out for sure once I have my car tuned next month and see how much power it puts down.
    I just installed new cams and followers because of ticking and the followers wearing poorly. I'll probably get a compression and leakdown done as well. Going to open up the cover as well and make sure clearances are good and everything is wearing nicely.
    Car has Karb airbox w/ CSL map sensor, 280/272 cams, ssv1 w/ 63.5mm catted/resonated section 1/2, stock section 3. Currently has a TTFS tune, but I feel like it should pull harder for the mods, but then again butt dyno can be deceiving. Going to have Hassan dyno tune at EAS sometime next month. I'll be happy with anything close to 350whp.
    I made 330 whp at EAS so with your setup you should do 360-380 whp easily.
  • fullyflaredd
  • jet_dogg
    ^what this guy said, no amount of tuning, elevation, gas etc is going to make your car down less than the guy with megan headers and lacking airbox
    If I were you I'd check compression and do leakdown.
  • stash1
    Something is not right.
    Ya, def a mechanical/timing issue going on there...power just looks down everywhere. It's also nosing over around 7,500rpms, and it should pull to 8,200+rpms no problem w/those mods. GL getting her sorted! I've been chasing similar issues w/mine, and 99.9% sure it's still somehow VANOS/timing related.
  • S54orzo
    What's the elevation and ambient temp during these pulls?
    Elevation was about 125 ft and temp was 80 °F
  • EthanolTurbo
    Originally posted by S54orzo View Post
    My thoughts as well, I'm planning on checking the timing this next week to see if something is off.
  • jet_dogg
    Car should be dyno'ing 350-360whp with those mods and torque in the 260s lb/ft, something definitely wrong and especially on such a low mileage.
  • S54orzo
  • ZiMMie
    Got my car on the dyno with Hassan on Tuesday as well.
    Mods:
    Evolve CSL Airbox
    280/272 Shrick Cams
    SSV1 Headers
    SS 63.5 Catless Sect 1
    SS 63.5 Dual Res Sect 2
    Dixis Muffler
    Turner Pulleys
    Car has 83K miles on it and has the big 3 done.
    Base pull w/CSL tune: 292
    Max Power: 310
    Drives a LOT smoother now than it ever did with the CSL base tune.
  • S54orzo
    Mods:
    Evolve CSL Airbox
    280/272 Shrick Cams
    SSV1 Headers
    Dixis Muffler
    Turner Pulleys
    Base pull w/CSL tune: 292 WHP
    Max Power: 310 WHP
    Click image for larger version  Name:	E46m3Dyno.png Views:	21 Size:	492.4 KB ID:	173381
    Click image for larger version  Name:	E46M3OnDyno.jpg Views:	0 Size:	100.9 KB ID:	173378
  • JaredU
    Finally got on the dyno today with Hassan,
    There’s not much in terms of performance shops and dynos around me, the shop I was at has a custom in floor dyno, whatever that means.
    Mods:
    Turner v2 CSL Airbox
    SGT headers
    SGT section 1 with 100 cell cats welded in
    Stock section 2
    Active Auto Gen 6 Section 3
    Base pull with a base map from Hassan was:
    292whp and 230wtq
    Final pull was:
    320whp and 252wtq
    AFR 12.5-13 a little richer in the midrange
    Was pouring rain here today, so the car just wanted to spin the wheels, but it pulls very nice. Big difference over the base tune too. Very happy with the driveability.
    Now goin in for rod bearings and vanos bullet proofing in a couple days while I’m on vacation
    Click image for larger version  Name:	FFEC2F92-7B44-4AC7-A9F8-50B4BD63E759.png Views:	0 Size:	35.5 KB ID:	173104
  • gixxer
    Why do almost none of you guys get afr logs
    Here's one showing afr from another recent dyno run,
  • Casa de Mesa
    I can get it. The pic I posted didn't have it, but I can get it mine were in the 13 range.
  • jet_dogg
    Excellent question.
