S54 Dyno Database
  • stash1
    Originally posted by Mspir3d View Post
    I’ll update mine, ~770 whp and 700 ft lbs. The BW maxed at 25psi, I’m planning on ordering a xona rotor hopefully. The afr was lower by .5 or so on the wideband in the car but still looking a little lean.
    Click image for larger version Name:	88355299-AEB4-48C1-9FBD-FE18F22E236E.jpeg Views:	0 Size:	191.3 KB ID:	93531
    Those are some very srs numbers sir, thanx for posting!
  • stash1
    Originally posted by Thonas View Post
ID:	92927 Click image for larger version
    Full Supersprint (Stepped headers, race cats, sport Muffler)
    Kassel MAP conversion, CSL Conversion
    Turner CSL air box
    Kassel dyno tune (mustang dyno)
    Congrats, nice gains, and thanx for posting!
  • Thonas
    Wow, those are some big numbers!! Your car certainly goes to 11
  • Mspir3d
  • CrisSilberGrau
    Thonas Congrats bro, really nice numbers. Excited to see your torque figures as I'll be going SS stepped and oversize dual throughout. Im at 325/250 whp/wtw on dynojet now (turner csl map, oe euro header, scza) , a little more oomph in the midrange never hurt anyone.
  • Thonas
    Turner CSL air box
  • stash1
    Originally posted by 332 View Post
    87k
    Cool, thanx!
  • 332
    can delete, edited original post!
  • stash1
    ^^^ Thanx for posting and providing mod details...and nice max power results for the relatively simple mods. However, low end torque figures look typical for an S54 w/single exhaust. How many miles on the car?
  • 332
    Click image for larger version  Name:	Screenshot 2015-01-19 17.11.39.png Views:	0 Size:	377.1 KB ID:	79809
    Alpha N, BW Elbow, Intake, Ebay Headers, 3" Single Exhaust, 87k on the motor
  • Anri
    Originally posted by paulclaude View Post
    Hi Anri,
    I wasn't actually operating the dyno myself so can't confirm if the dyno fan was left running between passes / refashing the ECU or not, but I can confirm we did back to back runs on the same final tune and even after repeated passes the result was within 2whp. It's only natural that if engine is left standing without airflow, IAT will rise resulting in ECU reducing ignition timing and knock out lower power figures. I'd assume the guys are EAS have a good cooling setup to simulate road airflow so runs should be accurate in comparison of how the car will perform on the road in the real world.
    On my own dyno I have a good cooling setup that i've setup simulate similar to road airflow conditions, as well as using the eddy brake control to set a ramp time that would be similar to the actual acceleration time on flat tarmac. We weren't shooting for social media numbers or anything like that, simply Blau's S54 is a particularly strong one so it made higher than usual numbers following tuning. I've tuned many of these engines and have also experienced a couple that make significantly better power than the majority of others. Why that is I don't know - maybe i'll get to strip one of them down one day and make some measurements and tests to find out
    Hi Paul,
    Thanks for your reply.
    Okay, looks like EAS Dyno is using 2 large and 2 small fans.
    The second guy (driver side) fan which is shooting air directly to the Air filter, ones I
    did this exact location and direct air to the air filter with the same exact fan and that
    pass was ~3-4 RWHP more than other passes. The more forced air is pushed inside
    the air box the more oxygen will be in % which is resulting little power gains.
    Yes I am aware of the fact that you are abroad, but you know, till you upload the file
    online engine must be off etc, re flash etc and the fans stay on and few
    degrees on the water temp and few on the oil cooler and then ones you start the
    engine the chilled fluids rush and cools down the block head and chamber then that
    will be strongest pass, so basically what I was asking on the hot passes is about 345ish.
    The dyno I do all of my work is using exact the same large fan as seen in the back
    at EAS but it's only 1. So I am missing 3 fans. For sure if I put our S54 at EAS will maintain
    the 354 +/- exact what you experienced.
    A single fan is not enough to simulate let say 80-90mph air pressure build in the front
    nose and specially with the unique S54 radiator ducting design, also the unique air
    ducting to the air filter box.
    As long as CR is good, leak down is good, Camshaft in the proper location, vanos as
    well we should see strong result. In S54 engine design there are several
    factors must be in a good order otherwise results are not as expected.
    How random this is the S54 I put together makes exact 348RWHP as well.
    Regards,
    Anri
  • stash1
    Originally posted by 2004LSB View Post
    The dyno operators @ EAS did say my car for whatever reason tested extremely high compared to other E46s that have come into their shop. From their experience, stock cars typically put down yep....275-280ish. Some cars even with full bolt-ons, cams, and E85 barely break 330s. So I guess I'm just really lucky and have a crazy strong motor from the factory.
    For whatever its worth, I did do the full Beisan systems VANOS upgrades from the start, and always did annual oil changes w/ Castrol 10w-60, whether if I did 300 miles for the year or 4,500. Engine never burned a drop of oil in the 8+ years of ownership.
    Who knows for sure, maybe your car already had a tune on it when you dyno'd stock? I just know from following/reading tons of various shops/dyno charts over the yrs that a lot of cars (in various stages of mods/tune) coming from EAS seems to produce unusually high numbers. Maybe if you ever get the opportunity to dyno on another local DJ, you could see if the numbers jive. Like I said, either way, those results are excellent...proof's in the delta!
  • 2004LSB
    Hi Anri,
    For the first run (and maybe even after the 2nd), I don't remember them turning on the HUGE cooling fan since the the room temps were in the 60s. According to the DynoJet run data, the recorded temps were 75 -76 degrees Fahrenheit, with 29% humidity and 29.99 inches of mercury for barometric pressure. After the 2nd run, they did switch it on the lowest setting to help circulate the air.
    For quick reference, here's EAS' typical fan setup for dyno testing:
  • paulclaude
    Hi Paul,
    Would you mind sharing the 348RWHP is this "Chilled" pass ? I assume yes ?
    I call chilled passes those that you have the engine off but the fan is
    still cooling the radiator down and say ~ 4min later you hop inside start the
    engine and make immediate pass.
    I call this passes "Social Media Number."
    The S54 engine I put together made 354RWHP on a Chilled Pass but
    run after run after run after run we land around +/-348-ish and this is the number
    I care about.
    There is a small tweak to be done but engine temp must be in low values or
    slight hi octane will work as well, all on the same ignition timing number.
    Thanks.
    Regards,
    Anri
    Hi Anri,
  • Anri
    strong engine!
    Hi Paul,
    I care about.
    Thanks.
    Regards,
    Anri
