S54 Dyno Database
  • stash1
    ^^^^ Nice results man, and thanx for providing the detailed info!
  • duracellttu
    Finally getting around to posting my results to this thread. My build thread LINK
    Here is a summary of the mods:
    2005 ZCP w/ 155k miles at the time of the build.
    Karbonius CSL Airbox (OEM trumpets) w/ OEM Snorkel and operational flap
    Lang Stage 2.5 head w/ Supertech valves and springs
    Schrick 280/288 cams, 12.5mm lift w/ DLC rockers
    Port exhaust side of head
    SS V1 stepped headers
    SS catted section 1
    SS resonated twin pipe section 2
    SS race mufflers
    Kassel Performance CSL ECU conversion
    Kassel Performance MAP sensor
    TMS underpower pulles, water pump and power steering
    SPAL electric fan conversion
    Turbo Toys V3 exhaust hub
    Custom tune by Paul Claudes
    91 octane pump gas
    TLDR version; 340 rwhp / 247 rwtq on a Dynojet w/ 91 octane pump gas. More power on the table once I get 93 octane gas.
    -- Dyno Curves --
    Blue: Mostly stock, aFe Stage 2 intake, Borla V2 midpipes and mufflers
    Red: aFe Stage 2 intake, AP V2 headers, CPI Euro section 1 w/ resonators, OEM section 2, Borla mufflers
    Green: Final tune results from CSL airbox conversion, custom head build, and full SS exhaust (full list above)
Name:	Post-CSL Conversion Full Comparison 22_Jun19.jpg
  • paulclaude
    Originally posted by 2004LSB View Post
    Adding mine to the new database!
    base run specs:
    • Stock US spec engine w/ mechanical fan
    • Stock US spec exhaust
    • 91 octane pump gas
    • Epic Motorsports tune
    • 281.87 WHP, 231.42 ft/lb
    Modded run specs:
    • Karbonius CSL intake w/ snorkel and factory plastic trumpets
    • Kassel MAP & intake air temp sensor kit
    • Mechanical fan
    • Paul Claude Tune
    • Euro headers & cats, stock section 2 & 3
    • 331.57 WHP, 254.26 ft/lb
    https://youtu.be/d_eMOxGe-hU
    Nice result and great sound! 😁
  • 2004LSB
    base run specs:
    Modded run specs:
    • Mechanical fan
    • Paul Claude Tune
  • stash1
    ^^^^ Nice Kareem, thanx for contributing to the database!
  • x Spades x
    So many of you know me as I'm one of the 288/280 "God Fathers" (the title is a work in progress damnit, lol). Anyway, my mods for both graphs (taken at the introduction of cams) are the same. The ONLY DIFFERENCE is the CF box (Evolve vs Karbonius w/CSL flap). I had a HUGE write up on M3forum about the differences (sound and feel). The last two dyno'd were BACK TO BACK)...
    Engine 172k miles
    Schrick 288/280 came
    Schrick coated followers
    Evolve airbox
    Euro headers
    Euro sec 1 (400 cell CATTED)
    OEM Sec 2
    Scorza exhaust (Oakville)
    HP: 334
    TQ: 247
    Mods:
    Engine 176k miles
    Schrick 288/280 cams (normal lift)
    Evolve vs Karbonius w/ CSL flap airboxes
    SSV1 headers
    SSV1 Spipe (200 cell CATTED)
    OEM Sec 2
    Evolve: 353hp, 246tq
    Karbonius w/ CSL flap: 347hp, 260tq
    Toss 15-20hp on top of both for NON-CATTED folks.
    Regards,
    Kareem
  • x Spades x
    Just dyno'd and the dashboard is still lit up (after 30 miles of driving). Is this normal (SMG)?
  • paulclaude
    i find the single larger roller to be more consistent due to the huge variables associated with the tyre interface being more controllable. Both Maha and DJ use a single roller. DD, mustang, DC, mainline use a twin roller although some brands have both twin and single rollers depending on model. i also have a theory that a 2WD dyno reads a bit more than a 4WD in 2WD mode.
    Many years ago i tested within a couple days a DD, DJ and Maha (couldnt get a booking with a Mainline) on an old shit box ill see if i can dig out the results. DD i find inconsistent really need to stick to 1 dyno and operator on those.
    Agree that a single roller system has it's benefits, however I think the consistency of the readout comes down to the setup of the dyno, how well balanced and aligned the rollers are etc. From what i've been told, the balancing and alignment of some roller sets can be poorly set from the factory, even from reputable dyno brands. My own is a 4-roller set, and I've had it all realigned and rollers balanced, and it's super consistent, usually within a couple of HP each pull.
    I've used both the later digital type DD and earlier analogue (DOS based) systems, and definitely agree that the later digital controllers are nowhere near as repeatable as the older type.
  • DESMDR3
    Originally posted by stash1 View Post
    Nice, seems like solid numbers for those mods! Was the B-spec an OTS tune or custom? Thanx for posting up!
    OTS tune. It’s been good, the car feels strong. I haven’t experienced any issues with drivability. When I get some more mods, I will definitely be going custom šŸ‘šŸ¼
  • digger
    I think I’m following...so, his car made 378BHP, and 294WHP...based on a 22% driveline loss vs. the more normally accepted 14-15%—correct? So, if we extrapolate, and figure the WHP based on say 14%, his actual WHP would be closer to 325? That seems a bit low to me (for the mods) vs. what I’m used to seeing. Typically, cars w/cams air boxes & supporting mods are in the 340-350WHP SAE on a Dynojet.
    the dyno is measuring the wheel hp and adding a correction, you cant say the bhp is correct and say the the losses should be 15% and therfore the whp is more like 325 thats kinda backwards. the rwhp should be the same sans assumption on inertia of machine plus vehicle drivettrain and physical losses due to different roller geometry and different CF standard..
    the DJ losses are at most 15% often 13% at peak hp and more like 10% at peak torque assuming BMW RWD, MT. if you look at healthy examples of BMWs from the good ol days (no turbo nonsense) thats what i always came up with.
    the issue is alot of the time peoples first stock baselines are rubbish so the delta is also rubbish obviously doesnt explain why some see 70whp gain and others 1/3rd of that
  • digger
    Digger,
    I always see them in the range of 272-282 at max put on pump 91 gas.
    Again small variations may vary in the the settings which contribute what you are seen
    or experienced.
    Correct, exactly what I have calculated in previous post. 378crank HP or (BHP UK)
    minus 22% which is Exact what this dyno calculates the losses in %
    Dyno-Jet per my personal experience have done quite few test is about 14%
    I never believed those who will put losses in 17%range..
    There is also another very important factor that plays roll in the dyno testings.
    - How low the car is, suspension changes can create losses, toe, axle changes due to
    being lowered etc.
    - After market wheels with much wider tires will also be considered as drag factor which
    All of this will reflect the end of the hp number.
    Regards,
    Anri
  • stash1
    Originally posted by paulclaude View Post
    Lets not start another dyno vs. dyno numbers debate - too many variables to compare from one to another. Numbers differ, dynos differ, they all have their positives and negatives. I personally prefer a braked dyno that can control ramp time to simulate actual road acceleration vs. a large inertial roller as per DJ which can't be controlled (on most DJ, anyway) - then you end up with acceleration times of the power run that differ from real world conditions. That load/acceleration difference can lead to inaccuracies in the tune when the car hits the road or track, especially for turbo/boosted setups. As for the coast down debate - it's exactly that, negative losses on coast down from ending RPM which is added to the curve to calculate for flywheel. How the dyno uses those measured losses can differ, but either way it's the most accurate way to determine transmission loss vs. a fixed correction factor.
    Anyway, here's one from my own Dyno, on my own track car.
    -Supercharged @ 10psi boost
    -Schrick 288/280
    -Euro Headers
    -2.5" Dual Section 1, 2 - decat
    -SS LWR rear silencer
    -Shite local fuel
    -AEM Infinity Standalone
    575HP / 379lb/ft TQ
    Nope, we’re def not going there! ...and nice Paul! Looks like a strong runner!
  • stash1
    Stan,
    My Man, you keep confusing based on what you are used to see on Dyno-Jet.
    Again, follow the logic here, UK will rate BHP crank HP much lower than BMW
    AG advertised the S54 at 343 DIN HP Crank.
    In this exact case, you do have the saying.... "Dyno is a tool to see the improvements from the parts being installed"
    aka Before and After. So if Martyn's S54 base run is 200rwhp and after tune box etc makes 230rwhp
    you have 30hp gain over the base run and that's it don't keep looking for logic to compare to DJ
    Accept the European Dyno services again as tool for "Before and After"..don't try to search for logic of
    what you and I are used to see.
    Like I mentioned before never been fan of this hp presentation. I am also pretty much sure that Dyno-Jet
    will have much stable weather factor calibration, I have seen the Dyno-Jet too change from different days
    from 14% down to 13%. So very little % in weather factor changes.
    Regards,
    Anri
    Ahhh sh*t balls then, thought I was really on to something. Sooo, there is absolutely no way to make any type of comparison between EU BHP numbers and a Dynojet—got it! I thought that you were just saying that the driveline % calc was off...but it just doesn’t flush.
  • stash1
    Lol don't worry about it dude. Trust me, I was expecting bigger gains with the airbox but no amount of vanos work could bring it any higher! Still a ~50bhp jump over stock isn't anything to sniff at.
    Perhaps we need to start a 100-200kph time thread for those with VBOXs / Draggy etc.
    Cool, yeah, 50 HP over stock is def noticeable in the seat of your britches! Ya, actual acceleration numbers would be a better metric to go by...providing traction isn’t a factor.
  • paulclaude
    -Schrick 288/280
    -Euro Headers
    -Shite local fuel
    575HP / 379lb/ft TQ
