S54 Dyno Database
  • bigjae46
    Originally posted by GregS86 View Post
    EPIC Alpha N tune
    SuperSprint Stepped headers
    3.5" custom exhaust
    4" custom intake with ITG filter
    Tilton clutch/flywheel
    Underdrive pullies
    327WHP, 260WTRQ(#'s are SAE corrected), however this motor will end up detuned for classing purposes.
    Click image for larger version Name:	S54 dyno.jpg Views:	4 Size:	82.2 KB ID:	305676
    Click image for larger version Name:	Cody G exhaust.jpg Views:	4 Size:	177.2 KB ID:	305677
    NIce! Swaintech coated headers?
  • fourmula1
    Originally posted by BMWfanz View Post
    Do you have AFR installed? Have you measured it on max tune map?
    Just exhaust sniffer while tuning. I think I can view the data in winpep. Epic tune, not concerned.
  • BMWfanz
    Originally posted by fourmula1 View Post
    I run detuned to 295HP for GTS3 but this is my max power tune.
    2003, 97k miles, A LOT of track hours/miles.
    Karbonius Race CSL Intake
    Status gruppe headers cut band clamped to BW race section 1
    BW race section 2 and 3
    Tilton clutch
    Underdrive pullies
    Suggested he cant get enough fuel to it to push further....at this point it is lines or fuel pump I assume, everything else has been changed or cleaned. Not that I need more for my class.
Name:	Screenshot 2025-05-19 152454.jpg
  • fourmula1
    Tilton clutch
    Underdrive pullies
  • GregS86
    EPIC Alpha N tune
    3.5" custom exhaust
    Underdrive pullies
  • samthejam
    Meant to attach this to other post.
  • samthejam
    Nothing crazy
    125k mile S54, no valve adjustment done to my knowledge.
    HTE "canned" Tune
    for these mods:
    Megan Headers
    BW Street/Track Exhaust 3.5"
    BW Silicon Elbow
    It has the stock airbox.
    Original MAF, probably original 02s. Happy with how it's doin.
  • digger
    Yeah but 2-3lbs makes a difference in the big picture. A lb here, a lb there…it all ads up.
    1 part in a 1000 lol
  • bigjae46
    it will replace 2-3 feet of single 3.5" with 2-3 feet of dual 2.375" (or whatever it is) which will be maybe 2-3lb so doesnt sifnificantly affect the core weight saving benefit (claimed 62) as the saving is not from piping sizes but lack of cats and lack of big resonator / big muffler but i do know people would be avoiding because of the torque dip
  • digger
    I am not worried about that region - track only. I might touch upper 3k a few times but usually it will be on purpose where I stay in a higher gear to deaden the torque because of a bump or tricky corner.
    The BW race is all about weight savings and top end power. I think if you move the merge back it will add unnecessary weight for those who would buy this. You certainly wouldn't put a BW race on for the sound.
  • bigjae46
    to boost 2.5-4k you could experiment with exactly doubling (or close to it) the current merge distance (which would still be slightly shorter/less than the stock merge distance by looks of it) but it will likely soften 4-5k a bit as a compromise but shouldnt hurt anyting above 5k. its expensive doing custom exhausts and hard to undo , so it depends how much it bothers you for the type of use
    i am suprised nobody as brought something similar to market as a bit less of a compromise and the 6-2-1 is the superior power setup over 6-2-H/X-2 with other advantages to boot
  • digger
    The dip between 2.5k to 4k...because of the BW race?
    Click image for larger version  Name:	Dyno.png Views:	140 Size:	46.3 KB ID:	301080
  • paulclaude
    Thanks for the insight!
    I had your canned tune for awhile and worked flawlessly for years! Very happy with it! Dyno’d at 325whp with it.
    I switched because I needed a detune for a NASA class.
    Great to hear! Certainly a healthy motor, especially with the stock camshafts.​
    This is promising, almost identical to my current build. BW race is the sections 1,2,3 correct? My only difference would be having the street/track which has a stock section 1. I'm curious where I'll fall and if I have that same low rpm dip.
    You won't have any dip with the Street/Track version that maintains section 1. Potentially, the full race version might have a touch more top end power 🙂
  • Darbshaw
    Epic Alpha-N dyno tune
    Megan headers
    3.5" BW race
    Crappy Injen Intake
    JB Racing Flywheel
    337whp/267yq
    That is about 12 more hp! Randy fixed the dip between 4.5k to 5.5k and it feels a lot better from 3.5k to 5.5k.
  • bigjae46
    Yes, cleaned by the guy here who did it years ago.
