Fix Your Rear Deck Lid/Parcel Shelf Rattle DIY (Tennis Ball Mod)
    This has been gone over before in previous forums, but I decided to make a new DIY for those who may need the info on here. After age the rear deck lid/parcel shelf starts to rattle with the Harman Kardon subwoofer when songs with moderate to strong bass are played (sometimes even minimal). There are many ways to fix this, but I used the tennis ball method. Hopefully this helps someone finally get rid of that annoying rattle.
    Here is a picture of the Harman Kardon sub, it is located in the trunk, under the deck lid.
    Click image for larger version  Name:	IMG_1813.jpeg Views:	0 Size:	150.5 KB ID:	19445
    The tools you need are a 8mm socket, an appropriate ratchet, a trim removal tool or a flat head screw driver, and of course tennis balls.
    Click image for larger version  Name:	IMG_1812.jpeg Views:	0 Size:	104.8 KB ID:	19446
    There are 4 black screws and 2 white clips which hold the subwoofer in place. Note that there are no screws holding the rear of the subwoofer. I have already removed the screws out of the front side in the picture below.
    Click image for larger version  Name:	IMG_1817.jpeg Views:	0 Size:	132.0 KB ID:	19447
    Left side:
    Click image for larger version  Name:	IMG_1814.jpeg Views:	0 Size:	86.2 KB ID:	19448
    Right side:
    Click image for larger version  Name:	IMG_1815.jpeg Views:	0 Size:	113.1 KB ID:	19450
    After removing the 4 screws, you need to pop out the white tabs on the front, I used the trim removal tool to pry them off.
    Click image for larger version  Name:	IMG_1818.jpeg Views:	0 Size:	54.6 KB ID:	19451
    After this your subwoofer should fall down, be careful not to strain the wires that are connected. You can see the white clips more visibly now.
    Click image for larger version  Name:	IMG_1819.jpeg Views:	0 Size:	158.1 KB ID:	19452
    You can choose to either disconnect the plug at the sub to clean out the subwoofer itself or place it on something that doesn't strain the wires.
    Click image for larger version  Name:	IMG_1820.jpeg Views:	0 Size:	128.1 KB ID:	19453
    If you look up now you'll see the two holes and also be able to feel the underside of the deck lid.
    Click image for larger version  Name:	IMG_1821.jpeg Views:	0 Size:	122.9 KB ID:	19454
    Feel around for the deck lid and wedge the tennis balls in to prevent rattle, make sure to take a look from the interior of the car to make sure the parcel shelf/deck lid has not popped up.
    Click image for larger version  Name:	IMG_1822.jpeg Views:	0 Size:	136.4 KB ID:	19455
    The re installation is everything but backwards, make sure to insert the two tabs facing the rear seats into their appropriate slots to get correct fitment.
    Click image for larger version  Name:	IMG_1823.jpeg Views:	0 Size:	187.4 KB ID:	19456
    As stated before, the reinstallation is pretty straightforward. I hope this helps or maybe informs someone how to remove the sub for other purposes.
    996TT
    Turbo E36 M3
    FZJ80
    Going on 11 years with tennis balls stuffed up there 馃槂
    DD: /// 2011.5 Jerez/bamboo E90 M3 DCT Slicktop Instagram
    /// 2004 Silvergrey M3 Coupe 6spd Slicktop zero options
      Just me or pics not working?
      Edit: fixed now
      Current:
      2003 BMW M3 Coupe 6MT - Alpine White/M-Texture Alcantara
        I have the same craftsman toolkit from the early 2000's. LOL great investment. I'll be doing this when update my system.
          Not to hijack the thread but out of genuine curiosity - was there ever any sort of reasonable DIY put together for later model cars? Obviously tennis balls did nothing for my Sept 2004 production date coupe.
          E46 M3 Coupe - 09/04 Production, 103k miles, Black/Black, 6MT swap, AS 0% kit, BBS RG-R + AS4鈥檚, CSL flash, Karbonius airbox, Euro header + Section 1, Koni Yellow, Xtrons, SAP Delete, lockdowns complete
            wat?
              I read a while back that on later model cars people go from the top, and pop the rear speakers out and stuff rags/cloth/tennis balls in the center off the rear shelf. Not sure how accurate that is though and if it will work. I didn't know the LCI version had a different trunk/sub setup compared to the older model ones
              996TT
              Turbo E36 M3
              FZJ80
                Apparently, it's obvious.
                  I know this is a popular thing, but am I the only one that never had that rattle?
                    *knock on wood* I've never had rattles either
                      Yeah my car doesn't do it either.
                        I stuffed six of 'em in there and I still get a subdued rattle, which disappears when the weather gets above 60 deg F.
                        The added weight high up is sapping my S54 power and has a negative impact on the handling.
                          I just did this and it worked like a charm! Some notes:
                          -I have a 2003.5 without HK so there was no sub to remove and subsequently no massive holes where the sub mounts
                          -I shoved tennis balls in the oval holes nearer to the front of the car and then pushed them towards the rear once in
                          -Had to make some serious gauges in the balls so that they would deform enough to fit
                            Don鈥檛 you suppose to cut balls in halves?
                              You have to get the carbon fiber balls. You need less weight that high. It'll completely negate your CF roof.
