I love my Precision Instruments split-beam torque wrenches, made in the US, certified, and can leave them on any setting.
Recommendations for Torque Angle Wrench
Good poiint...Always remember there is spring back when doing an angle torque which a manual angle torque gauge will catch. IIRC it was about 3-4 degrees.Originally posted by cobra View PostPersonally I did not trust the precision of the cheaper electronic torque angle gauges so I went with a manual one. It ended up working great. Very repeatable, easy to use, no doubts about whether the angle is being measured properly.
If I was doing this job on a regular basis I would look at one of the nicer electronic 1/2" drive ones from CDI or something.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I use a 1/2", 3/8", and a 1/4" torque wrench. IMO a 3/8" torque wrench is ideal for rod bearings and most fasteners. A 3/8" torque wrench will typically provide enough leverage to get a fastener up to 100 ft/lbs with some effort but not so much that is makes it super easy to go well beyond the spec. It takes about 10 degrees to be 15%-25% over the target.
I'll be the first to admit that I'm bad about using a 1/2" torque wrench on lug nuts. The 3/8" makes it much harder to go over.
