My E46 M3's body is a 2005 Cabrio SMG. My motor and tranny are NOT. They are from an early 2000's SMG coupe....2002? 2003? Long story.
At considerable expense I bought every part on the tranny schematic here: https://www.realoem.com/bmw/enUS/sho...56#23317530787
My mobile mechanic (my car is home up on four six ton jack stands) says he cant see where ANY of the above parts go. Do we have to remove the tranny mounts and support it with a jack and TILT it down? The exhaust, drive shaft, guibo have ALL been removed, so far. Huge job!
Are ALL years of the SMG trannies the same? Attached are two photos my mechanic took on MY SMG tranny from a different SMG M3 somewhere in the early 2000's
One photo is of the drivers side tranny and a crappy one of the passenger side tranny. The kit to replace all those parts on the passenger side (in the schematic I referenced from realoem) was quite expensive and not returnable since we opened the blister pack.
He replaced the GPS(gear position sensor) with a guaranteed used one. But things are not quite right yet. I want to figure out what to do next. I dont want to keep driving my half wrecked Lexus beater to work while my daily driver M3 is up on jack stands.
EDIT: We also plan to replace these parts on advice from robgill: 12142296184 Crankshaft speed sensor and new o-ring.
plus: 13621433076 Temperature sensor coolant / oil
Only thing is that I see these on THIS schematic: https://www.realoem.com/bmw/enUS/sho...98#13621433076
Is THAT the tranny I have???? Sure looks different than this one.... the one that I based ALL my parts list from: https://www.realoem.com/bmw/enUS/sho...56#23317530787
