StopTech (the company) problems.
    I've used Zeckhausen (https://www.zeckhausen.com/catalog/index.php?cPath=24) in the past for StopTech parts. I actually have a pile of parts i've been meeting to use to rebuild a pair of ST40 calipers.
    Don't do it with stoptech (centric) parts. Use girodisc, racing brake, bremo...
    And I'm not saying that becuase of this thread.
      You will not get custom hats for less than $2k. We would charge you more than twice that, and that's the number we throw out there for people we actually want to make hats for. One-offs are REALLY expensive because you can't amortize out all the time of designing, programming CNC, and QC of the final product. God forbid you have to scrap a part and start over...
      I'm not aware of Pro-System doing hats or rings in such small quantities, but I could be wrong. As I mentioned earlier, the piston seals and dust boots are universally available.
      As for pro-system I have quite a good relationship with them so maybe its different but I doubt it. I contacted them about making replacement rotors that work with stoptech C43 hats and caliper for my e36 and was quoted ~$350/rotor with no minimum quantity assigned. Hat design will obviously be more expensive but it is an option and they have pretty much endless customization options.
        How often do the rotor hats of a two-piece rotor need to be replaced?
        And what wears out, the holes where the friction ring hardware goes through?
          From my research, the hats are a lifetime part. It's the hardware that needs replacing with every disc change. The only reason I needed to buy hats is because the kit I purchased came with everything but the hats/discs, but thankfully they're available. When placing the order my Race Technologies rep did vet me out, wanted pictures of said calipers, clear pictures of stampings on the caliper, etc., I'm certain to ensure I've got authentic parts.
            The Rach Technologies rep also quoted hardware kits (1 per corner) right? Are you going to replace to rear bracket or let it ride for the time being?
              He did suggest that, so I got new hardware, brake lines and I think I'll let the rear bracket ride, doesn't look terrible. Worst case I can have a buddy just mock one up at his machine shop if needed. Was going to powder coat before rebuilding them but the paints in great condition still which is a blessing.
              I now have a set of Porsche Cayenne calipers that I'll need to sell.
                As someone who just picked up a set of ST40 trophy fronts for my car, this is a great thread to have read through. I got an incredible deal on the setup so I’m not too mad at myself. Glad to know things like the dust boots and seals are pretty much off the shelf stuff and readily available.
                  The best part is the choice of brake pads. You can use pads from Porsche 928/944/968 and a specific MY 911. Tons of good and inexpensive options.
                    993 Big Red rears for sure. I think it's the same as one of the 964 fronts.
                      Anyone has any updates on the new factory and return of supply for Stoptech?
                        No, seeing less and less of stoptech. I don't see them making a comeback since many cars are now using fixed calipers which eliminates the hard parkers. Then I get the feeling that attendance at track days is down a bit AND more cars have fixed calipers. On those cars, not sure if Stoptechs would provide an upgrade that's worth the cost. Might as well go AP Racing.
                        I've been a fan of Stoptech because it provides better performance at a lower cost. Cost being a big reason I've used them.
                          Well thats a shame. Hopefully i can use them a few years longer once i refresh them and parts are available. Thanks for the update brother.
                            Should be good indefinitely as long as the bespoke stoptech parts don't go bad. Caliper body and bridge are the only parts that I don't think you can get or easily make. Crossover tube is just bending some brake line and flaring the ends. Bleeders, pistons, seals, boots...all standard. Hardware is hardware. Might need to get Fastenal to make something.
                              I was under the impression Stoptech sourced their parts from overseas?
                              2004 Dinan S3-R M3
                              2023 X3M Competition
                                Did Stoptech ever release a carbon brake system for the E46 M3?
