IB Journal
    IB Journal
    Back into an IB e46 after 10ish years away
    Found a pretty clean 06 SMG car grey interior 66k miles.
    first up is to do an interior swap to
    black or mtexture. Assembling parts to get working on it.
    then plan to do the classic mods (csl trunk / csl intake) and enjoy it
    thankful this is an active forum - am certain I’ll need a little help along the way!
    Word
      Congrats, looks really nice!
      I have two black seats and door cards if you’re interested.
      997.1 GT3 Carrara White/“Special Leather Black”
      C43 AMG Diamond Silver/Red​
        Thanks I have all that
        need alutech door armrests to have complete swap over
          If the trim is in good condition, you should be able to swap over the grab handle/trim to the black door cards. Removing the leather pads is a PITA but doable without breaking anything.
            ya I guess I am going to try it - hopefully the parts survive brought them all into the house so they are warm
              Good luck! Need to be patient when prying off the pads. The six small pins on the pads are a pain to separate from the retainers on the trim piece, but they will slowly come out. Be careful with the rear tab on the pad as well.
                Ok update - Color change well underway
                Before
                  During
                    Current situation
                      Still needs some bits and pieces - new trims ordered should have that done
                      Using Alex from the forum to refinish some bits of trim
                      Swapped the competition trim tops onto black trim bottoms for arm rests etc
                      Annoyingly I seem to have a bad passenger rear RTAB as I can wiggle the wheel and get toe change - RTAB moves
                        Do you know why the leather on the rear seat is so bunched up?
                          Looks normal to me?
                            Looks normal to me?
                            Leather looks bunched up a bit on the centre sections of the rear seat compared to below
                            Probably just age/wear. Bit of heat and leather treatment might help with it.
                            Click image for larger version  Name:	Used-2004-BMW-M3-Coupe-E46-LOW-Miles-Carbon-Black-6-Speed-Manual-Collector-Quality-Example.jpg Views:	0 Size:	97.7 KB ID:	209983
                              I wonder if it's bunched because it got damp or wet at some point.
