I need a good low range torque wrench in my collection of tools. Something that will accurately torque from say 5-50ft lbs. Specifically looking for a torque wrench I can trust for a Vanos lockdown in the future.
Whats a good low range torque wrench?
InstagramTags: None
As you may or may not know, torque wrenches are less accurate in towards their outer bounds. So if you're thinking about torquing a fasteners in, say, the 7 to 10 ft lbs range (of which there are many on VANOS work) then its not best to use the hypothetical range product you noted.
For low torque stuff, look at wrench indicated by inch lbs which is really where these products are placed. Common ranges are 10 or 20 in lbs to 150 or 200 in lbs. Your 7 ft lb fastener would be torqued to 84 in lbs, so you're right in the sweet spot of the range.
Look for a wrench with a dual scale, so in lbs on one side and nm on the other - very handy with BMWs.
I like CDI's torque wrenches and they are buy-once kind of deal. But to torque everything for VANOS lockdown, or other work you'll later do, you'll need a bigger brother in ft lbs. So its really a matter of needing two...🙃
Note that I am a homegamer so see if you get any comments from the pros (the real ones)'05 M3 Convertible 6MT, CB/Cinnamon, CSL Airbox&Flap, PCSTuning, Beisan, Schrick 288/280, SS V1's & 2.5" System, RE Stg 1&SMF, KW V2, CB PS, Apex EC-7R
- Likes 6
Ha, shows what I know...oh well. This M3 is really the only car I've wrenched on besides my jeep, and the jeep I don't care as much, I just feel it out by hand.
My M3 has me actively wanted to seek out to new projects, one of these days I hope I don't bite off more than I can chew!2004 Silbergrau Metallic 6MT
Seems to be discontinued now, but I use this one for the small bolts where the torque value is critical: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Probably something similar out there.
On a related note, how do you guys calibrate your torque wrenches? I've only seen the expensive digital calibration tools and the more diy friendly methods that involve using a luggage scale or similar. However, I'm not sure I trust those.2002 Topasblau M3 - Coupe - 6MT - Karbonius CSL Airbox - SSV1 - HJS - Mullet Tune - MK60 Swap - E86 Front Triangulation - ZCP Rack - Nogaros - AutoSolutions - 996 Brembos - Slon - CMP - VinceBar - Koni - Eibach - BlueBus - Journal
I actually have 4 torque wrenches. 1/4" drive in inch pounds as noted above. Then a 3/8 drive that goes from about 20 Newtons to more than I can torque with short wrench. Then 1/2" drive 50 ft lbs to 250 ft pounds. And finally I also have a 3/4" drive that goes to 450 ft lbs. (Actually that one I bought for work but I have used it for wheel nuts and such.)
Agree completely on the CDI torque wrenches. My CDI (http://www.cditorque.com/) is identical to a mechanic friend's Snap-On (Snap-On owns CDI) at about 1/2 the price.Originally posted by jbfrancis3 View Post... I like CDI's torque wrenches and they are buy-once kind of deal. But to torque everything for VANOS lockdown, or other work you'll later do, you'll need a bigger brother in ft lbs. So its really a matter of needing two...🙃....
Feff
Anyone have any experience with this wrench?
I would personally look for a used Snap-on on eBay. I have a digital 3/8 in Snap-on which I like a lot. The click type Snap-on wrenches are good too. They sell for a fraction of the retail price on the used market. After you buy it, send it out to a place like Team Torque to get re-calibrated. You would likely come in cheaper than those torque wrenches in the Catalog above.'06 BMW M3 6MT Coupe - TiAg/Imola
Agreed, and what I did.Originally posted by Titaniu//M View PostI would personally look for a used Snap-on on eBay. I have a digital 3/8 in Snap-on which I like a lot. The click type Snap-on wrenches are good too. They sell for a fraction of the retail price on the used market. After you buy it, send it out to a place like Team Torque to get re-calibrated. You would likely come in cheaper than those torque wrenches in the Catalog above.
I could, but I like my split beam wrench too. Just easier to whip that out, not worry about batteries being charged, and not worry about banging up a very expensive torque wrenchOriginally posted by Obioban View Post
I mean... you could start using it. I just use them as my torque wrench.
My Digitool Solutions DWA-2501 is fantastic. Worth a look.
I use that for engine stuff in 1/4", and then I have a QD2FR75 daily driver. Also use a larger cheapo Neiko Pro 1/2" beater for lugs and what not. Check them all against an ACDelco ARM602-4 pretty frequently, but also try to send them out for calibration... sometimes.Last edited by ethan; 05-06-2020, 09:00 AM.
