My car has 64K on it and everything seems fine, the previous owner supposedly had VANOS bolts done so I assume that would mean he did the cam bolts.
I was wanting to bulletproof this thing but wondered if I'm jumping the gun due to low mileage. I am the 4th owner though and I have no idea how good or bad the car was treated in the past. Overall the car seems to have been very well cared for and many preventative maintenance items have been taken care of.
In my reading I see that replacing oil disc is a must if your in there, but replacing the Exhaust Hub is only advisable IF you see damage. I thought the breaking of those tabs on the exhaust hub was the "big deal" thing to go wrong.
Unless you had the Exhaust Hub MPI inspected or something similar how would you know if it's OK, just by seeing the tabs are still attached? So wouldn't a full "lockdown" also involve replacing the Exhaust hub as well?
Considering getting the built/cleaned unit from another forum member here, he does not use a beisan oil disc though, he re-drills them himself.
