Thanks for the replies. I will take a pic this weekend , when I take the valve cover off amd show you guys.
Vanos time?
So this morning around 5 oclock, I was driving about 50mph and I hit a racoon, front right side of bumper, I saw the racoon too late and couldn't swerve, I kept on driving, so the washer fluid light came on. I was like ok the tank is broken. Then the radiator light came on. I was 15 mins away from home, so I was like im going to drive home. The temp needle went into the red. I drove the car like that for 5 mins. Then heard noise coming from the engine at around 2000-3500 rpm, sounding like loose marbles. Made it home, I didn't check the car properly because I had to go to work. But I see my oil cooler hanging and scraping the floor. I hope i done need a engine. Most likely a head gasket. What should I check first. I will check later on today take a good look and see what's really broken, oil cooler, radiator , bumper.
Hopefully that's all it is. No coolant, the motor's relying on merely the oil for that job, so the first thing that comes to my mind is a spun bearing from cooked oil. Doesn't take long.Originally posted by M3powerzz View PostThe temp needle went into the red. I drove the car like that for 5 mins. Then heard noise coming from the engine at around 2000-3500 rpm, sounding like loose marbles. Most likely a head gasket.
Well put coolant in the car, still leaking from the radiator. The noise is gone, I started it up, no noise , but wasn't under load. Still rev smooth so spun bearing is out I assume, will fix the radiator and start from there. I will still do a compression test. I think the noise was from my aux fan hitting a plastic that was broken. Will update you guys .. Fyi I did feel sorry for the racoon I hit. Rip...i know I should of stop when it went into the red. But i was on the highway and wad 5-10 mins from home. So I wanted to get off the highway.Last edited by M3powerzz; 06-09-2023, 03:48 PM.
Only use the Genuine BMW tool.Originally posted by M3powerzz View PostAnyone ever use this alignment tool,
https://www.amazon.com/Camshaft-Sett.../dp/B08332DDRB
Ok, so I adjusted the timing. I got to tdc, loose the 3 hub bolts, then rotated crank shaft, loosen the other 3 bolts, fully retard camshaft turning counter clock wise, put alignment bridge on, adjusted intake camshaft , dowel went in smoothly. Now for the exhaust when I turn it counter clock wise., the dowel didn't go in, the camshaft needed to go coo terclock wise a little more, but the camshaft couldnt go any more. So I put everything back together and Now I'm getting code p0014 b camshaft position timing, over advanced or system performance bank 1. So my timing still off?
